Sony CDRW Enclosure HELP
Postby animex on Sat Oct 11, 2003 9:15 pm
Sony Spressa USB CRX100E/X CD-RW
that is what i got, an old cdrw that i took the drive out and installed a formatted hard drive in the enclosure. i tried to look up the hard drive through the disk management but didnt see any and the drive didnt show up in my computer either. anyone can help me out on this?
animex
Postby BoGMan1a on Sun Oct 12, 2003 12:46 am
Did you make sure that the drive is set to master? The enclosure needs to have the drive set to master in order to be recognized. I have swapped CD-RW drives on this kind of enclosure before, but never a HDD. That being said, they are both ide devices so the swap should be do-able and the bandwidth should be adequate for it. Good Luck!! 8)
Main Computer:
ASUS A7N8X deluxe
AMD Athlon XP2500
1Gb PC3200
6600GT AGP
BENQ 1620
NEC 3500AG
Lite-on 52246S
Lite-on LTC-48161H
1 Tb of internal HDD space
750+ Gb external storage
Dual Boot Win2000Pro/XP Home
BoGMan1a
