Sony DRU-510A DVD Rip speed?
Postby nXt on Sat May 31, 2003 9:16 pm
Just ordered one, was wondering if anyone knew what the average DVD ripping speed is? Thanks
nXt
Postby hoxlund on Sat May 31, 2003 9:31 pm
well the dvd read speed is 12x, so right around there
Postby nXt on Sat May 31, 2003 9:41 pm
hoxlund wrote:well the dvd read speed is 12x, so right around there
well That can't be. My liteon 163 DVDrom is 16x rated, and average rip of dvds at 5x (though i've seen it going 10x at 13megs per second)
nXt
Postby dhc014 on Sat May 31, 2003 9:48 pm
Using the DVD Burner to rip will only shorten its life. I'd recommend using your Lite-ON to rip since it isn't quite as expensive as a burner.
dhc014
Postby hoxlund on Sat May 31, 2003 10:48 pm
trust me i won't use my new dvd burner for anything else but backing up dvd movies and burning dvds
Postby tazdevl on Sat May 31, 2003 11:47 pm
dhc014 wrote:Using the DVD Burner to rip will only shorten its life. I'd recommend using your Lite-ON to rip since it isn't quite as expensive as a burner.
huh?
RIG:
tazdevl
Re: Sony DRU-510A DVD Rip speed?
Postby jsl on Sun Jun 01, 2003 7:00 am
nXt wrote:Just ordered one, was wondering if anyone knew what the average DVD ripping speed is? Thanks
DVD video is limited to 2x speed with the DRU-500A(X) and I doubt Sony has changed this on the DRU-510A.
jsl
Postby hoxlund on Sun Jun 01, 2003 10:01 am
what do you mean, has 4x on both dvd+-r
and 4x on dvd+rw and 2.4x on dvd-rw
Postby jsl on Sun Jun 01, 2003 2:56 pm
Ripping speed on CSS protected DVD video discs.
jsl
Postby hoxlund on Sun Jun 01, 2003 6:33 pm
toward the end, my 16x aopen slot loading (pioneer) goes to 6x
