TDK 840G firmware issue and burning problems!!!
Postby Papag on Tue Jan 31, 2006 8:52 pm
Well, i wasn't able to use the firmware from 1.07 to 1.11... I get an error message that says "firm ware update is failed" System error (Win32) code 1117. The whole reason for the firmware was to try and burn using memorex DVD -R 4x discs.
Here is my log. I installed a fresh copy of 6.0.0.0 because it used to work before the upgrade to 6.6.0.8 It was a clean install and uninstall so thats not the problem. Can anyone tell me what is wrong?
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 4/2/2003 10:13:43 AM
Nero version: 6.0.0.0 (Nero Express)
Recorder: <TDK DVDRW840G> Version: 1.11 - HA 2 TA 1 - 6.0.0.0
Adapter driver: <> HA 2
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <LITE-ON LTR-48125W >Version: VS06 - HA 2 TA 0 - 6.0.0.0
=== Scsi-Device-Map ===
CdRomPeripheral : TDK DVDRW840G 1.11 nvidesm Port 1 ID 0 DMA: ?
CdRomPeripheral : LITE-ON LTR-48125W VS06 nvidesm Port 1 ID 1 DMA: ?
DiskPeripheral : ST3120026A 8.01 nvidesm Port 1 ID 0 DMA: ?
DiskPeripheral : WDC WD1200BB-98DWA0 15.0 nvidesm Port 1 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 215MB (220316kB)
Memory in use : 57 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
31.1.2006
ISO compilation
7:36:09 PM #1 Text 0 File Isodoc.cpp, Line 5451
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
7:36:09 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
7:36:09 PM #3 Text 0 File Writer.cpp, Line 127
Writer TDK DVDRW840G running
7:36:09 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3814
7:36:09 PM #5 Text 0 File Burncd.cpp, Line 3081
Turn on Disc-at-once, using DVD media
7:36:10 PM #6 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 2297887 (510:38.37)
Last address to be written: 1795087 (398:54.37)
7:36:10 PM #7 Text 0 File DlgWaitCD.cpp, Line 229
7:36:10 PM #8 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: TDK DVDRW840G, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AF1
7:36:10 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 757
original CD pos #0 + 1795088 (1795088) = #1795088/398:54.38
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1795088 blocks [TDK DVDRW840G ]
7:36:10 PM #10 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to TDK DVDRW840G on a DVD-R media
7:36:10 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder TDK DVDRW840G for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -618319872
7:36:10 PM #12 Phase 24 File dlgbrnst.cpp, Line 1818
Caching of files started
7:36:20 PM #13 Phase 25 File dlgbrnst.cpp, Line 1818
Caching of files completed
7:36:20 PM #14 Phase 36 File dlgbrnst.cpp, Line 1818
Burn process started at 4x (5,520 KB/s)
7:36:20 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
7:36:20 PM #16 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 11:13,008 (673008ms) -> OK
7:36:20 PM #17 Text 0 File DVDR.cpp, Line 1407
Recording mode: Sequential Recording Mode
7:36:20 PM #18 Text 0 File Mmc.cpp, Line 18119
Set BUFE: supported -> ON
7:36:20 PM #19 Text 0 File DVDR.cpp, Line 1522
Start write address at LBA 0
7:36:20 PM #20 Text 0 File Cdrdrv.cpp, Line 7827
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:36:29 PM #21 SCSI -500 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x08E10000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
7:36:29 PM #22 Text 0 File Writer.cpp, Line 455
19:36:29.296 TDK DVDRW840G : WriteBuffer reduced to 32768 Bytes
7:36:29 PM #23 Text 0 File Writer.cpp, Line 318
19:36:29.312 - TDK DVDRW840G : Queue again later (Intervall : 11msec)
7:36:37 PM #24 Text 0 File Writer.cpp, Line 444
SCSI-Layer send CDRERR_BUFFER_TO_BIG to writer
7:36:37 PM #25 Text 0 File Writer.cpp, Line 455
19:36:37.484 TDK DVDRW840G : WriteBuffer reduced to 30720 Bytes
7:36:45 PM #26 Text 0 File Writer.cpp, Line 455
19:36:45.484 TDK DVDRW840G : WriteBuffer reduced to 28672 Bytes
7:36:53 PM #27 Text 0 File Writer.cpp, Line 455
19:36:53.500 TDK DVDRW840G : WriteBuffer reduced to 26624 Bytes
7:37:01 PM #28 Text 0 File Writer.cpp, Line 455
19:37:01.484 TDK DVDRW840G : WriteBuffer reduced to 24576 Bytes
7:37:09 PM #29 Text 0 File Writer.cpp, Line 455
19:37:09.484 TDK DVDRW840G : WriteBuffer reduced to 22528 Bytes
7:37:17 PM #30 Text 0 File Writer.cpp, Line 455
19:37:17.484 TDK DVDRW840G : WriteBuffer reduced to 20480 Bytes
7:37:25 PM #31 Text 0 File Writer.cpp, Line 455
19:37:25.484 TDK DVDRW840G : WriteBuffer reduced to 18432 Bytes
7:37:33 PM #32 Text 0 File Writer.cpp, Line 455
19:37:33.484 TDK DVDRW840G : WriteBuffer reduced to 16384 Bytes
7:37:41 PM #33 Text 0 File Writer.cpp, Line 455
19:37:41.484 TDK DVDRW840G : WriteBuffer reduced to 14336 Bytes
7:37:49 PM #34 Text 0 File Writer.cpp, Line 455
19:37:49.484 TDK DVDRW840G : WriteBuffer reduced to 12288 Bytes
7:37:57 PM #35 Text 0 File Writer.cpp, Line 455
19:37:57.484 TDK DVDRW840G : WriteBuffer reduced to 10240 Bytes
7:38:05 PM #36 Text 0 File Writer.cpp, Line 455
19:38:05.484 TDK DVDRW840G : WriteBuffer reduced to 8192 Bytes
7:38:13 PM #37 Text 0 File Writer.cpp, Line 455
19:38:13.484 TDK DVDRW840G : WriteBuffer reduced to 6144 Bytes
7:38:21 PM #38 Text 0 File Writer.cpp, Line 455
19:38:21.500 TDK DVDRW840G : WriteBuffer reduced to 4096 Bytes
7:38:29 PM #39 Text 0 File Writer.cpp, Line 455
19:38:29.484 TDK DVDRW840G : WriteBuffer reduced to 2048 Bytes
7:38:37 PM #40 SCSI -500 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x097F1000
Sense Code: 0x26
Sense Qual: 0x02
7:38:37 PM #41 Text 0 File Writer.cpp, Line 448
Recorder-Buffer cannot be reduced any more
7:38:37 PM #42 CDR -500 File Writer.cpp, Line 335
SCSI command aborted
7:38:37 PM #43 Text 0 File ThreadedTransfer.cpp, Line 227
7:38:37 PM #44 Text 0 File ThreadedTransfer.cpp, Line 221
7:38:46 PM #45 SCSI -500 File Cdrdrv.cpp, Line 1361
Sense Code: 0x26
Sense Qual: 0x02
7:38:50 PM #46 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
7:38:50 PM #47 CDR -500 File WriterStatus.cpp, Line 160
7:38:50 PM #48 TRANSFER -24 File WriterStatus.cpp, Line 160
Could not perform end of Disc-at-once
7:38:50 PM #49 Text 0 File dlgbrnst.cpp, Line 1678
7:38:50 PM #50 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) :cry:
Papag
Postby Ian on Tue Jan 31, 2006 9:26 pm
It looks like you're using the NVIDIA IDE drivers. I wouldn't be surprised if they were causing the problem.
Postby Papag on Tue Jan 31, 2006 10:17 pm
That was the problem, I was just coming back to post what it was. I upgraded to the Nvidia Nforce MCP2 IDE controller so that the primary and secondary drives would actually show up under computer manage. I was able to configure them to DMA, and now it works. I forgot to upgrade the drivers, after I reinstalled my nvidia chipset. I feel like a noob. :lol:
Papag
Users browsing this forum: Google [Bot] and 3 guests
