TDK DVD-Ram 9.4GB + Samsung S202J problems - need help
Postby nousername on Wed Feb 06, 2008 10:33 pm
Hi all,
I have problems with this combination; it is not possible to format and write on this media with Samsung S202J (SB01)? Actually, I formatted this media (FAT32 in WinXP SP2) for once but after that (when i tried to write on this) my system locked up and after restarting the system I got an error - "Medium Format Corrupted" (but for just one side of it - other side of the media can't be formatted but without this error) while formatting/writing again. I also tried with DVDForm and InCD, but nothing changed, got an same error. I don't think that it's TDK's fault/fail; any suggestions?
thanx for replies.
nousername
Postby hoxlund on Wed Feb 06, 2008 11:34 pm
you can't format a disc with fat32, thats meant for hard drive
cds have CDFS file system
Postby Ian on Wed Feb 06, 2008 11:59 pm
Actually, you can format DVD-RAM with FAT32.
I'm not sure why that TDK disc doesn't work with the drive. Does anyone know if it supports the double sided 9.4GB media?
Postby nousername on Thu Feb 07, 2008 10:43 am
As Ian said, it can be formatted as FAT32 that is suggested for XP users rather than formatted as UDF mostly that is suggested for Vista users.
I think, it supports this Type 4 DVD-Ram, because it recognized and formatted this media without any problem before this error :roll:. Maybe I should try it with Vista or different DVD-Writer (but which brand?). I guess it's Samsung's fault, but I don't know why? :roll:
BenQ DW 1650
Samsung S202J
nousername
