Is there anything wrong with these scans?
Postby Nocturnal on Fri Aug 26, 2005 4:48 pm
Plextor 716AL
Nocturnal the Unbeatable
Nocturnal
Postby Nocturnal on Fri Aug 26, 2005 4:51 pm
Btw, I was attempting to make a back up copy of my Windows XP Home SP2 Upgrade disc.
Nocturnal
Postby eric93se on Fri Aug 26, 2005 5:33 pm
try using the "disc quality" option, and scan the disc again. Your drive had problems reading the disc back, so that means there is a higher error rate. If you want a high quality back-up then you will have to choose a slower burn speed.
Benq DW-1640
eric93se
Postby Scour on Fri Aug 26, 2005 5:59 pm
What´s the brand of the CD-R you used?
