Trying multi session audio disc , unchecking finalize opt?
Postby brucefl on Sat Apr 30, 2005 5:29 pm
I bought a new computer and it has Nero VS 6. I go to nero smartstart, choose audio, make an audio cd, add the audio tracks, from one cd, but I have several I want to utilize, I try click the more in nero exp, but it does not give me any choice to allow files to be added later. So I click the burn it is greyed out, I click the more in that window, the finalized cd is checked and greyed out. If I click the nero at the bottom it goes into nero burning rom, but finalized cd is checked and greyed out.
I was able to get it clear once, but when I went back to do another session witha few more songs, it says it may not work? Using regular cd-r's
If I go into just the burning rom, I can't find options to do multidisk as I use to in cdcreator?
brucefl
Postby burninfool on Sat Apr 30, 2005 5:52 pm
An audio CD will not playback properly unless it's finalized and a single session.
Read this: www.cdrlabs.com/phpBB/viewtopic.php?t=18153&highlight=
finalizing no problem, problem finalizing when complete?
Postby brucefl on Sat Apr 30, 2005 7:21 pm
I have several disc. I want to burn 1 or 2 songs. Problem is I do two off once, then burn but it wants to finalize. If I have say 5 disc, 1 or 2 songs on each disc. I first few songs, then want to go to another disc, but it wants to finalize each burn?
Say I want to burn some today, and have to leave, I burn 3 or 4 songs, but I don't want to finalize the disc until I record ALL I want to.
In easy cd creator you could burn a few songs and not close or finalize the disc. Then you could go back add some more to the disc.
After I get what I want on the disc, then I would finalize it?
Hope that isn't more confusing. I don't want to do the disc in one session, or at one time.
brucefl
Postby burninfool on Sat Apr 30, 2005 7:56 pm
Why don't you rip the CD's to your HDD in WAV,then when you get 80 minutes of songs burn a CD.
Another option(if your player supports MP3) is to make a multi-session MP3 CD.
A multi-session audio CD will not work properly,read the post from CCampbell...he works for Nero.
can do
Postby brucefl on Mon May 02, 2005 7:02 am
Yes, I read the post, all the way through, after I posted my last message. Looks like putting them on the HD is about the only option, unless I want to update my other program.
thanks for the help
brucefl
