Ultra DMA4 mode being reset to PIO...
Postby freeloader on Sun Jul 23, 2006 3:33 pm
I have a pair of Lite On SOHW 1673S burners. I normally use only the master unit to burn CDs and DVDs with Nero. Every once in a while the burn buffer indicator in Nero begins cycling wildly from the high 90%s down to low single digit %s. This is associated with the Device Manager setting "IDE ATA/ATAPI Controlers\Primary Channel/Advanced Settings\Device 0\ULTRA DMA 4" transfer mode being changed to PIO for some unknown reason. The usual result is a coaster from a bad burn.
As soon as the controler driver is uninstalled and the PC rebooted the Ultra DMA 4 setting is restored, the buffer stays in the high 90%s and the burns are good again.
So, my question:
What keeps changing the transfer mode from Ultra DMA4 to PIO?
I haven't a clue as to why it happens. There doesn't seem to be any pattern to it. The only sign that there is a problem is after a burn has begun and the buffer indicator begind cycling meaning that a new coaster is being made.
Thx for any advice on this.
freeloader
Postby dodecahedron on Sun Jul 23, 2006 3:49 pm
i can never find the link for this but...
WinXP, when it detects a certain number of errors on the IDE channel, automatically switches down to PIO.
maybe a bad cable???
Postby hoxlund on Sun Jul 23, 2006 11:49 pm
bad ide cable/low computer specs
reaching on this one but, low power through the power supply rail (crappy psu)
Postby TCAS on Mon Jul 24, 2006 3:32 am
Try to upgrade your Motherboard Bios.
Postby parcival on Tue Jul 25, 2006 6:29 am
You can get this by just reading a badly scratched disk. Google for resetdma.vbs for a script that reset to dma (or go here: http://winhlp.com/WxDMA.htm has a full explanation of the problem as well). There is no need to uninstall/install drivers. Occasionally check your settings and run this script when xp "knows better that you" and switches it to pio.
parcival
Postby freeloader on Wed Jul 26, 2006 9:07 pm
Thx guys for your input.
I just built this PC a little over a year ago. While I didn't go for a screamer, I find it hard to believe that it has low specs.
ASUS P5AD2-E Premium - MoBo
Intel 630 3GHz - CPU
2GB Kingston DDR2 533 - RAM
2x Seagate 7200.7 160GB SATA - HDD
Antec NeoPower 480 - PS
2x Lite On SOHW 1673S - DVD
etc.
Basically, I wanted something upgradeable to dual core and 64 bit when it pays to do so.
It runs at internal case temps under 100*F, barely.
Hardware utilities show voltages as stable in the specified ranges.
There is one more BIOS update I can make, but supposedly it only addresses a low speed CPU fan setting.
With that said, I do have a couple of IDE cables left over from building the PC I could try.
I've copied that VB script to Notepad, but I've never played with script before. I'm a bit at a loss as to what to do with it. I can get it figured out if I need to.
I'm reluctant to do a BIOS update unless it is absolutely necessary. I've had a firmware update blowup in my face once. It ruin a perfrectly good piece of hardware. I'm a bit paranoid about those types of updates.
If you have any more thought on this, I'm still open to hear them.
Thx again, guys.
freeloader
Postby hoxlund on Thu Jul 27, 2006 1:47 am
vbs scripts are very dangerous, i personally wouldn't try it
if your not acting like a total tool when updating bios then you'll be ok
first thing is to try a new cable, switch up the power connectors also
all else fails, it could be just a failing drive
fork over the $50 or less and get a new burner
also i just installed x64 windows yet again today, after having xp pro for couple of months
theres no getting over the nice speedy quickness of a 64bit OS
Postby MacClipper on Thu Jul 27, 2006 10:55 am
dodecahedron wrote:i can never find the link for this but...
Try this thread,
http://www.cdrinfo.com/forum/tm.asp?m=81131
MacClipper
Postby dodecahedron on Fri Jul 28, 2006 2:19 am
MacClipper wrote:Try this thread,
thanks MacClipper.
yeah that containd a link to the MS article i was thinking of.
