Verbatim Producer 44 Dual Format DVD Burner
Postby eagleskys on Fri Jul 18, 2003 8:18 pm
Hi
Do you know if the new Verbatim Producer 44 Dual Format DVD Burner is identical to the NEC 1300? Besides, are you going to review the burner and are there any other revews to read? And do you have a picture that shows the front panel of the Producer 44? I would appreciate your help.
eagleskys
Re: Verbatim Producer 44 Dual Format DVD Burner
Postby Ian on Fri Jul 18, 2003 9:25 pm
>> Yes
>> Yes. Dunno when. I think cdrwcentral.com has a review.
>> It looks like this:
Postby eagleskys on Sat Jul 19, 2003 12:45 pm
Thanks Ian. Can you just think of any site that has already reviewed the Verbatim Producer 44? Unfortunately, I can't find it at CRWCentral. Thanks.
eagleskys
Postby Ian on Sat Jul 19, 2003 9:13 pm
eagleskys wrote:Thanks Ian. Can you just think of any site that has already reviewed the Verbatim Producer 44? Unfortunately, I can't find it at CRWCentral. Thanks.
Look at their review of the NEC ND-1300A
