What's the best and cheapest way to copy a protected CD?
Postby UALOneKPlus on Mon Feb 09, 2004 1:15 am
I bought the Hoyle Casino 2004, and even after a full install, the game will not play without the CD in the drive!! :evil: :evil:
Since I fly a lot, I don't want to have the original CD with me as I will probably break it or lose it.
None of the Nero copies of the CD work, so I am now forced to "pirate copy" this lame CD just for backup purposes!! :evil: :evil:
Stupid Hoyle. Had I known about this problem, I would never have bought their game. They DESERVE to have their games illegally copied, stupid a$$hats.
Now, I need your recommendation to copy this POS CD, since I've never had to copy a protected CD before.
I have the LiteOn CDR-5W48, LTR-52246S to use for copying.
Thanks for your suggestions!
-Danny Kaye
UALOneKPlus
Postby pranav81 on Mon Feb 09, 2004 1:52 am
Dear UALOneKPlus,
Hi.You can try using CloneCD and Alcohol 120%.Those are good programs for copying copyrighted CD's.
I have used CloneCD and it worked beautifully for me.You can get it at http://www.slysoft.com
See ya later,
::Pranav::
pranav81
Postby hoxlund on Mon Feb 09, 2004 12:03 pm
just use alcohol or daemon tools to run the cd emulated from your hard drive
Postby pranav81 on Tue Feb 10, 2004 7:59 am
Dear UALOneKPlus,
Listen to the master pirater. :D He sure knows his stuff.
::Pranav::
pranav81
