WinXP DMA problem/missing Advanced tab in Device Manager
Postby johnc19 on Thu Apr 28, 2005 8:50 am
Hi, I unistalled my secondary IDE as I could not enable DMA on my DVD burner. Note: DVD burner was still installed at that time. When I re-installed Secondary IDE.....the 'Advanced' tab in Win XP ie IDE ATA/ATAPI controllers -> Primary/Secondary IDE Channel -> Advanced Settings tab is now missing. It is no longer there for my Secondary IDE. Any idea on how I get it back? The DVD burner is now performing a lot faster, so it looks like DMA is turned on. Ok ..any advice will be good.
_______________________________________
moved from FAQ forum to DVD Recordable forum.
pleast don't post questions in the FAQ forum.
- dodecahedron
johnc19
Postby dodecahedron on Fri Apr 29, 2005 4:00 pm
hi johnc19 and welcome to CDRLabs.
well, simple fixes to try:
in Device Manager, try again uninstalling the Secondary IDE Channel and reboot.
another thing to try: uninstall the DVD burner too!
Postby HardwareHarry on Sat Apr 30, 2005 10:03 am
@Johnc19 at my system Intel(845PE) chipset, the DEVICE tabs vanished after I installed the Intel Accellerator Driver, so if you have a Intel chipset only install Intel INF. set, then the tabs are coming back.
success, Harry
HardwareHarry
Postby burninfool on Sat Apr 30, 2005 10:09 am
Did you upgrade to SP2?I've noticed it's been removed so use Nero Infotool to check.
Postby HardwareHarry on Sun May 01, 2005 12:30 pm
In my case SP2 did the XP Pro completely lock, so I installed XP again without SP2 but ZoneLab ZoneAlarm Firewall wich I understand and for me on Cable is completely safe !
Harry
HardwareHarry
No luck yet with enabling DMA
Postby johnc19 on Fri May 06, 2005 10:53 am
Hi all,
Thanks for the advice...but no luck yet with enabling the DMA or getting the Advanced Tab back. I have unistalled and reinstalled the DVD drive and the IDE controller and noluck. I did check if DMA was enabled through Nero...and nope...not enabled!
I do have the Intel 845PE chipset....so I will try uninstalling the Acceleraor program.
OK all...let me know if you think of anything else.
johnc19
Postby dodecahedron on Fri May 06, 2005 2:26 pm
if you have the IAA installed, then you do not have that tab in Device Manager, and DMA is controlled from the IAA.
