Backup firmware on AOpen drive
Postby CDRecorder on Thu Jul 31, 2003 1:33 pm
I have an AOpen 52x OEM drive, and I would like to update it to the latest firmware. Is there any way I could back up the original firmware first?
When I updated the firmware on my AOpen 32x drive (last year), I selected the "backup firmware" option in the flasher from AOpen's site, but it didn't work.
Re: Backup firmware on AOpen drive
Postby dhc014 on Thu Jul 31, 2003 1:47 pm
CDRecorder wrote:I have an AOpen 52x OEM drive, and I would like to update it to the latest firmware. Is there any way I could back up the original firmware first?
It depends on who the true manufacturer of the drive is. If it's a Ricoh like I assume your 32x was, then it helps to enable Windows 98/ME compatibility mode on the program when flashing if you want to make a backup.
dhc014
Postby CDRecorder on Thu Jul 31, 2003 1:55 pm
OK. I'll try that. Thanks! :D
BTW, this drive has JustLink and flashes with RFlash, so I assume it's a Ricoh clone.
Postby CDRecorder on Thu Jul 31, 2003 2:02 pm
I tried it both with compatibility mode (98/me) on and with it off, and I got this message both times:
Cannot update for different Type Code.
*** NG ** NG ** NG ***
Make sure Selected Source File.
My drive is identified as: 52X24X52X CD-RW 1.04. I am trying to update to the 1.07 version of the firmware from AOpen's web site.
BTW, I know the drive is AOpen because it says so on top of the drive.
Edit: Corrected the version number of the firmware.
Postby dhc014 on Thu Jul 31, 2003 2:04 pm
Maybe try some of the steps in this threadon rpc1.org. More useful information is at the end of the thread.
dhc014
Postby CDRecorder on Thu Jul 31, 2003 2:08 pm
Thanks, I'll try that, too.
Postby CDRecorder on Fri Aug 01, 2003 3:06 pm
I tried the DOS flasher, but I couldn't see any "backup" option. I would really like to back up my existing firmware.
Postby dhc014 on Fri Aug 01, 2003 4:17 pm
I have the 1.04 backup if you need it.
dhc014
Postby CDRecorder on Fri Aug 01, 2003 4:35 pm
Thank you; I would like to have the 1.04 backup. I'll PM you my e-mail address. :D
Postby CDRecorder on Fri Aug 08, 2003 5:44 pm
I finally got a chance to try the DOS flasher. The drive now has the 1.07 firmware installed.
Postby CDRecorder on Fri Aug 08, 2003 5:59 pm
The drive (now with firmware 1.07) seems to be working fine. :D
Thanks for the help!
