BenQ 1620Pro - BIG problems!!
Postby Tobber on Fri Dec 23, 2005 10:45 pm
Hi there,
I have a big problem regarding my DVD-RW drive BenQ 1620Pro.
It just doesn't burn any DVD+R anymore. Haven't had the chance to try DVD-R yet. The drive just stops with the lead-in and aborts. I tried different media-brands (Verbatim, Ricoh, Ritek) and tested the drive with another PC but no luck...
It writes CD-R just well. It reads DVDs. The drive detects the DVD correctly and offers correct writing speeds. Tried different versions of Nero and other freeware burning programs. It's always the same.
But wait, here comes the tricky part. This isn't the first time I experience those problems. This is my THIRD drive that shows the same problems. The first one lasted for about 5 months, the second one 1 month and the third one about 1 week or in other words 10 DVDs...
I haven't changed my configuration since last year. I reinstalled WinXP when I received my third drive. The drive runs in DMA-Mode, I use the latest firmware.
Any suggestions???
Thanks for every answer and plz excuse grammar & style... I'm not a native speaker :)
Tobber
Tobber
Postby CowboySlim on Sat Dec 24, 2005 2:21 am
Not to worry, Tobber - I never would have guessed.
You do a lot better than some of our native born.
Postby TCAS on Sat Dec 24, 2005 2:27 am
You must give your system components spects (CPU,HD, memory, above all your system power supply) for the people to be able to give any reasonable and useful advise.
Postby Tobber on Sat Dec 24, 2005 5:17 am
Ok, here's my configuration:
beQuiet 400W power supply
Asus A7N8X-Deluxe
Athlon XP-M 2600 @ 2400 MHZ ~ 45°
1 GB MDT-RAM @ 200 MHZ (Memtest finds no errors)
Gigabyte nVidia Gforce 6800
1x S-ATA Hitachi 160 GB
1x IDE WD 1200JB 120 GB (Primary Master)
1x IDE Maxtor 80 GB (Primary Slave)
1x Plextor DVD-Rom (Secondary Master)
1x BenQ 1620Pro DVD-RW (Secondary Slave but tried Secondary Master alone as well)
WindowsXP SP2 (since third drive. Before I used WinXP SP1)
IDE, CPU, Network driver nVidia nForce 5.10
VGA-Driver nVidia Forceware 81.95
OK, that's about everything, have I forgotten something? The system runs quite smoothly. Don't have had any Bluescreens or something like that for quite some time now. The only problem is with my DVD-RW drive. Of course, I can't rule out the possibility that those ... at BenQ just sent me 3 defective drives but I'm not as certain of it anymore... :)
Tobber
Postby bill on Sat Dec 24, 2005 1:59 pm
It appears that you have done a reasonable amount of testing.
Are both of the computers that you've used for testing using N-Force IDE drivers?
bill
CD-RW Supplier
Postby Tobber on Sat Dec 24, 2005 4:37 pm
No, the other one uses a VIA-Chipset.
Just want to make sure that nothing in my computer is killing off my DVD-RW drives one by one. Virus, defective cable?? Something like that. Maybe it sounds silly but after 3 drives nothing sounds much more sillier to me than getting a fourth drive and having the same problems all over again...
BTW: Merry Christmas :)
Tobber
Postby CowboySlim on Mon Dec 26, 2005 12:35 am
VIA chipsets can be very weak.
Have you had problems when the VIA are not involved?
Have you had problems when the VIA are involved?
Problems with and without VIA?
Postby Tobber on Mon Dec 26, 2005 8:43 am
Haven't had any problems with the via-chipset either. I use a DVD-RW with the via-chipset as well and it works just fine.
My problem is that the BenQ DVD-RW just refuses to burn DVDs. This happend when installed in my system running on a nforce2-chipset. It just doesn't work in a via-chipset pc as well...
Tobber
Postby bill on Mon Dec 26, 2005 10:57 am
A little late but Merry Christmas!
To summarize, you said-
DMA is enabled.
Using latest bios. BenQ bios release or third party?
You tried the BenQ on two different computers.
Tried different media.
CD-R writes ok.
Reads DVD ok.
You tried the BenQ on the second IDE channel as the master device. Did you set the jumper to master?
As a final test I would try to disable all third party applications that auto start. XP burning engine, anti-virus, Alcohol, Movie Factory etc.... Then try using Nero again and post the error log statement here. Something in the log might provide the answer.
bill
bill
CD-RW Supplier
Postby Tobber on Mon Dec 26, 2005 11:29 am
BenQ original Bios.
Jumper is set to master.
Will try your suggestion with the autostart and errorlog. May take me a day.
Thanks for your help so far :)
Tobber
Postby Tobber on Mon Dec 26, 2005 9:17 pm
OK, so here we have 2 logs.
Log 1 is with installed nvidia-ide-drivers. Curiously enough nero reports DMA-DISABLED... IDE-Driver reports DMA-ENABLED.
Log 2 has been taken with deinstalled nvidia-drivers. Doesn't change anything. DMA is enabled but the drive still stops with the lead-in.
logs.rar
(5.57 KiB) Downloaded 539 times
Tobber
Postby bill on Tue Dec 27, 2005 4:13 pm
Finally found my copy of Winrar... Anyway, guys I'm stuck, still trying to learn how to read the logs.. Can anyone help with Tobber's logs?
What is- "Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)"? and "Sense Key: 0x03 (KEY_MEDIUM_ERROR"
With Nvidia drivers installed-
Tobber
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 18:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
Rekorder: <BENQ DVD DD DW1620> Version: B7W9 - HA 1 TA 2 - 6.6.0.16
Adapter-Treiber: <nvatabus> HA 1
Drive buffer : 2048kB
CD-ROM: <BENQ DVD DD DW1620 >Version: B7W9 - HA 1 TA 2 - 6.6.0.16
=== Scsi-Device-Map ===
DiskPeripheral : HDS722516VLSA80 V34O si3112r Port 0 ID 0 DMA: Off
DiskPeripheral : WDC WD1200JB-75CRA0 nvatabus Port 1 ID 0 DMA: Off
DiskPeripheral : Maxtor 4D080H4 nvatabus Port 1 ID 1 DMA: Off
CdRomPeripheral : BENQ DVD DD DW1620 nvatabus Port 1 ID 2 DMA: Off
=== CDRom-Device-Map ===
BENQ DVD DD DW1620 I: CDRom0
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 728MB (745592kB)
Memory in use : 28 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
27.12.2005
UDF/ISO Zusammenstellung
01:43:04 #1 Phase 112 File dlgbrnst.cpp, Line 1832
Die Neuzuordnung der DVD-Videodateien ist gestartet
01:43:04 #2 Phase 114 File dlgbrnst.cpp, Line 1832
Die Neuzuordnung der DVD-Videodateien ist beendet (keine Datei wurde verändert)
01:43:04 #3 Text 0 File Isodoc.cpp, Line 6356
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
Character set : ISO 9660
Joliet :FALSE
01:43:04 #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Videodateien sortiert
01:43:04 #5 Text 0 File Reader.cpp, Line 127
Reader running
01:43:04 #6 Text 0 File Writer.cpp, Line 122
Writer BENQ DVD DD DW1620 running
01:43:05 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
01:43:05 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
01:43:05 #9 Text 0 File Burncd.cpp, Line 3233
01:43:05 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2279247 (506:29.72, 4451MB)
01:43:05 #11 Text 0 File DlgWaitCD.cpp, Line 282
01:43:05 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: BENQ DVD DD DW1620, Media type: DVD+R
01:43:05 #13 Text 0 File DlgWaitCD.cpp, Line 448
01:43:05 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
0: TRM_DATA_MODE1 ()
original disc pos #0 + 2279248 (2279248) = #2279248/506:29.73
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2279248 blocks [BENQ DVD DD DW1620]
01:43:05 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [BENQ DVD DD DW1620] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4667899904, ISRC ""
DAO layout:
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2279248 | lead-out | 1 | 0x41 | 0x00
01:43:05 #16 Phase 24 File dlgbrnst.cpp, Line 1832
Cachen von Dateien
01:43:05 #17 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
01:43:05 #18 Phase 25 File dlgbrnst.cpp, Line 1832
Cachen von Dateien fertig
01:43:05 #19 Phase 36 File dlgbrnst.cpp, Line 1832
Start des Brennvorganges mit 12x (16.620 KB/s)
01:43:05 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
01:43:05 #21 SCSI -1066 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x04A00600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
01:43:05 #22 CDR -1207 File DVDR.cpp, Line 5065
Book Type automatisch auf 'Aktuelle Rekordereinstellung' gesetzt
01:43:05 #23 Text 0 File DVDPlusRW.cpp, Line 665
Start write address at LBA 0
01:44:05 #24 SCSI -1176 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x04250000
Sense Code: 0x72
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x72 0x01
01:44:05 #25 CDR -1176 File Writer.cpp, Line 311
Fehler beim Fixieren der Session
01:44:05 #26 Text 0 File ThreadedTransfer.cpp, Line 228
01:44:05 #27 Text 0 File ThreadedTransfer.cpp, Line 222
01:44:05 #28 SCSI -1176 File Cdrdrv.cpp, Line 1180
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x03
01:44:05 #29 Phase 127 File dlgbrnst.cpp, Line 1832
Erzeugen von DVD High-Kompatibilitätsgrenzen
01:44:05 #30 Phase 129 File dlgbrnst.cpp, Line 1832
Erzeugen der DVD Grenzen erfolgreich beendet
01:44:05 #31 Phase 38 File dlgbrnst.cpp, Line 1832
Brennvorgang nicht erfolgreich mit 12x (16.620 KB/s)
Existing drivers:
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 03.06.2004 10:40:46 (Adapter driver for rec)
Registry Keys:
Without Nvidia IDE driver installed-
Tobber
Windows XP 5.1
IA32
WinAspi: -
Rekorder: <BENQ DVD DD DW1620> Version: B7W9 - HA 1 TA 0 - 6.6.0.16
Adapter-Treiber: <atapi> HA 1
CD-ROM: <BENQ DVD DD DW1620 >Version: B7W9 - HA 1 TA 0 - 6.6.0.16
DiskPeripheral : WDC WD1200JB-75CRA0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 4D080H4 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : BENQ DVD DD DW1620 atapi Port 1 ID 0 DMA: On
DiskPeripheral : HDS722516VLSA80 V34O si3112r Port 2 ID 0 DMA: Off
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 730MB (748496kB)
Use Inquiry : 1
27.12.2005
02:04:09 #1 Phase 112 File dlgbrnst.cpp, Line 1832
02:04:09 #2 Phase 114 File dlgbrnst.cpp, Line 1832
02:04:09 #3 Text 0 File Isodoc.cpp, Line 6356
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet :FALSE
02:04:09 #4 Phase 111 File dlgbrnst.cpp, Line 1832
02:04:10 #5 Text 0 File Reader.cpp, Line 127
Reader running
02:04:10 #6 Text 0 File Writer.cpp, Line 122
02:04:10 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
02:04:10 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
02:04:10 #9 Text 0 File Burncd.cpp, Line 3233
02:04:10 #10 Text 0 File DlgWaitCD.cpp, Line 270
02:04:10 #11 Text 0 File DlgWaitCD.cpp, Line 282
02:04:10 #12 Text 0 File DlgWaitCD.cpp, Line 2483
02:04:10 #13 Text 0 File DlgWaitCD.cpp, Line 448
02:04:10 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
02:04:10 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
02:04:10 #16 Phase 24 File dlgbrnst.cpp, Line 1832
Cachen von Dateien
02:04:10 #17 Text 0 File Burncd.cpp, Line 4120
02:04:10 #18 Phase 25 File dlgbrnst.cpp, Line 1832
02:04:10 #19 Phase 36 File dlgbrnst.cpp, Line 1832
02:04:10 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
02:04:10 #21 SCSI -1066 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04AB0600
Sense Code: 0x24
Sense Qual: 0x00
02:04:10 #22 Text 0 File DVDR.cpp, Line 5896
Drive: BENQ DVD DD DW1620
Book Type request [gen]: Physical disc type, write to EEPROM
Changing the Book Type was finished successfully, return code 0
02:04:10 #23 CDR -1211 File DVDR.cpp, Line 5056
Book Type auf 'DVD+R' gesetzt
02:04:10 #24 Text 0 File DVDPlusRW.cpp, Line 665
02:05:33 #25 SCSI -1176 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04200000
Sense Code: 0x72
Sense Qual: 0x01
02:05:33 #26 CDR -1176 File Writer.cpp, Line 311
02:05:33 #27 Text 0 File ThreadedTransfer.cpp, Line 228
02:05:33 #28 Text 0 File ThreadedTransfer.cpp, Line 222
02:05:33 #29 SCSI -1176 File Cdrdrv.cpp, Line 1180
Sense Code: 0x72
Sense Qual: 0x03
02:05:33 #30 Phase 127 File dlgbrnst.cpp, Line 1832
02:05:33 #31 Phase 129 File dlgbrnst.cpp, Line 1832
02:05:33 #32 Text 0 File DVDR.cpp, Line 5896
Book Type request [gen]: DVD-ROM, write to EEPROM
02:05:33 #33 Phase 38 File dlgbrnst.cpp, Line 1832
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 06.01.2005 05:00:00 (Adapter driver for rec)
Registry Keys:
bill
bill
CD-RW Supplier
Postby dodecahedron on Tue Dec 27, 2005 4:47 pm
i would say bad media. (KEY_MEDIUM_ERROR)
Postby Tobber on Tue Dec 27, 2005 6:12 pm
Hmm, that would be pretty strange.
I tested A-Grade Ricoh, A-Grade Verbatim and Ritek.
All where burnt pretty well und now aren't burnt anymore...
Tobber
Postby bill on Wed Dec 28, 2005 7:53 am
Tobber wrote:Hmm, that would be pretty strange.
Tobber,
Maybe you have been unlucky and had three drives fail but sometimes it's the media or system it's installed on. You tried the BenQ in two different computers, what do they have in common? The BenQ, the media, maybe the Nero version...and what else???. Is Nero IN-CD installed? Is Roxio installed?
Please try the following-
Can you try another media (+R) as Dodec suggested?
Also, please try -R media.
Try to write about 500 mb of data to a +R disk.
Here is a quote from another forum (I lost the link and can't give credit), it may be helpful-
"Thanks all - tried everything you offered but in end, I uninstalled Nero V6.6.0.12 and used clean up tools to get rid of all traces of Nero. I installed Nero V6.3 and all worked OK - could make DVD+Rs again that were usable.
On closer visual examination of DVDs produced by V6.6.0.12 I found there was no recording on start of track near centre of DVD. I compared this with DVD+R creat with V6.3 and recording starts at beginning of track.
Why??? - Idon't know."
Please keep posting. I'm curious what the final solution will be.
bill
bill
CD-RW Supplier
Postby dodecahedron on Wed Dec 28, 2005 10:12 am
bill said some of what i was gonna say.
try other media. TY if you can get some is a good idea.
try DVD-R.
important: if you can, try installing the drive in another computer and see if it works there.
shouldn't matter, but if you have a bit of time, try removing all other optical drives you have leaving just the BenQ 1620.
what firmware do you have on it?
Postby Tobber on Wed Dec 28, 2005 12:18 pm
I think I did get those 3 defective drives in a row... lucky me.
Sometimes the DVD-RW just doesn't recognize a blank DVD+R / DVD-R. If I put an CD or DVD into the drive it does read it. AFTER that it recognizes the blank DVD as well...
I tried a DVD-R (Verbatim) as well... same problems.
Firmwareversion of the DVD-RW is "B7W9". The problems began with version "B7V9" so I upgraded. The last drive was running well on B7W9 and the problems started with the latest FW...
All other optical drives are removed at this time.
The last drive didn't work on the other PC as well. Didn't test this one but somehow I suspect..........................
I tried burning with 3 different programs or versions of a program. Nero 6.6, Nero 7 Demo and CD BurnerXP Pro. Problem remains the same.
After the last defective drive was replaced I reinstalled WinXP and formatted C:\. I didn't install Roxio, InCD, DaemonTools or something like it.
I contacted the technical support of BenQ... again. I asked them to replace the 1620Pro with a 1640. Maybe I get lucky for a change :D
I'll keep you posted...
Tobber
Postby dodecahedron on Wed Dec 28, 2005 12:33 pm
we'll keep our fingers crossed for you :)
that would be nice if they gave you a 1640 [-o<
Postby Tobber on Wed Feb 22, 2006 6:40 pm
Just wanted to tell you... after a VERY, VERY LONG struggle with BenQ, I received an 1640 today.
It works for now so I'm burning like HELL right now :D
Thanks guys for your help... see you soon (or hopefully not that soon :))
Tobber
Postby CowboySlim on Wed Feb 22, 2006 7:44 pm
Whew!
Postby dodecahedron on Thu Feb 23, 2006 1:32 am
well, i guess you won't be using that DW1620 anytime soon :)
enjoy your new drive.
Postby Tobber on Thu Feb 23, 2006 12:21 pm
Yeap, the 1640 is a pretty fine drive... LEAD-OUT is WAY faster compared to the 1620... I like it =D>
Tobber
