Burning Problem
Burning Problem
Postby skandaluz on Tue Dec 30, 2003 2:05 pm
Hi, I was wondering if any of you can help me. Alright, i'm having this burning problem. I'm using Nero Express 5.5 or whatever on a TDK 4800B 48x/24x/48x and it keeps giving me this error. I've tried different types of media and it keeps giving me this error. Below is a screenshot of the error.
Does anyone know why this is happening?
Thanks in advance.
skandaluz
Postby NoSmartz on Tue Dec 30, 2003 3:20 pm
If you haven't tried already,try burnin' at a slower speed.Like 24x or 16x to see what happens.Use RW's(high speed if ya got em')so no wasteage.
Or just try to burn at 4x with an RW to see if burnin is OK all around.
E
Soren Kierkegaard
NoSmartz
Postby skandaluz on Tue Dec 30, 2003 5:52 pm
Sorry about the picture buts heres the picture again.
skandaluz
Postby dodecahedron on Tue Dec 30, 2003 6:02 pm
why don't you try again, and when it fails click the Save button to save the log, then post it here.
then we'll have some more information, and maybe someone will be able to help you out.
it's a good idea to also supply info about your system (hardware, OS etc.)
Postby skandaluz on Tue Dec 30, 2003 6:44 pm
Alright saved the log and i didn't know how else to do this but i just posted it as is below. Btw, my system is running windows xp w/ SP1, Abit NF7 mobo, WD 120gb. if you need any other information, feel free to ask.
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/26/2002 1:06:32 PM
Nero Version: 5.5.9.0 (Nero Express)
Recorder: <TDK CDRW4800B> Version: S7S5 - HA 2 TA 0 - 5.5.9.0
Adapter driver: <> HA 2
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI
CD-ROM: < JLMS DVD-ROM LTD-166S>Version: DS08 - HA 1 TA 1 - 5.5.9.0
Adapter driver: <nvidesm> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1200JB-00CRA1 17.0 nvidesm Port 1 ID 0 DMA: ?
CdRomPeripheral : TDK CDRW4800B S7S5 nvidesm Port 1 ID 0 DMA: ?
CdRomPeripheral : JLMS DVD-ROM LTD-166SDS08 nvidesm Port 1 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 235MB (241588kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: On
CD-Image
30.12.2003
3:51:45 PM #1 Phase 90 File dlgbrnst.cpp, Line 1560
3:51:45 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
3:51:45 PM #3 Text 0 File Writer.cpp, Line 129
Writer TDK CDRW4800B running
3:51:45 PM #4 Text 0 File Burncd.cpp, Line 3474
Turn on Disc-At-Once, using CD-R/RW media
3:51:45 PM #5 Text 0 File ThreadedTransferInterface.cpp, Line 685
0: TRM_DATA_MODE1 (ISO9660)
original CD pos #0 + 250834 (250834) = #250834/55:44.34
relocatable, CD pos for caching/writing not required/not required, patch infos
3:51:47 PM #6 Text 0 File DlgWaitCD.cpp, Line 198
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 250833 (55:46.33)
3:51:49 PM #7 Text 0 File DlgWaitCD.cpp, Line 1393
Recorder: TDK CDRW4800B;
CDR code: 00 97 26 54; OSJ entry from: Lead Data Inc.
ATIP Data:
Special Info [hex] 1: F0 00 80, 2: 61 1A 36 (LI 97:26.54), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
3:51:53 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 835
Prepare recorder TDK CDRW4800B for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 514015232
3:51:53 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 685
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 250834 blocks [TDK CDRW4800B ]
3:51:53 PM #10 Phase 24 File dlgbrnst.cpp, Line 1560
Caching of files started
3:51:53 PM #11 Phase 25 File dlgbrnst.cpp, Line 1560
Caching of files completed
3:51:53 PM #12 Phase 36 File dlgbrnst.cpp, Line 1560
Burn process started at 4x (600 KB/s)
3:51:53 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1967
Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #0
3:51:53 PM #14 Text 0 File Mmc.cpp, Line 11793
StartDAO : CD-Text - Off
3:51:53 PM #15 Text 0 File Mmc.cpp, Line 16205
Set BUFE: supported -> ON , SMART-BURN : ON
3:51:54 PM #16 Text 0 File Mmc.cpp, Line 12039
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 37 2e 22
3:52:00 PM #17 SCSI -500 File Cdrdrv.cpp, Line 1406
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x02D00000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
3:52:00 PM #18 CDR -500 File Writer.cpp, Line 330
SCSI/IDE Command aborted
3:52:00 PM #19 Text 0 File ThreadedTransfer.cpp, Line 222
3:52:00 PM #20 Text 0 File ThreadedTransfer.cpp, Line 216
3:52:04 PM #21 Phase 38 File dlgbrnst.cpp, Line 1560
Burn process failed at 4x (600 KB/s)
3:52:04 PM #22 Text 0 File Scsicmd.cpp, Line 383
Existing drivers:
Registry Keys:
skandaluz
Postby dodecahedron on Tue Dec 30, 2003 7:09 pm
couple of suggestions:
1.update to the latest version of Nero 5.5, i think it's 5.5.10.54. you are using 5.5.9.0. can't hurt to try, at the worst uninstall and reinstall the older version.
2. if i'm not mistaken your motherboard uses Nvidia chipset. are you using the Nvidia IDE drivers? it so, try rolling back to the MS drivers. the Nvidia IDE drivers are know to be problematic.
3. in the log you are using Lead Data. try using better media - Taiyo Yuden if you have/can get it.
what are you trying to burn - data?
obviously the problelm is here:
Code: Select all
Sense Code: 0x26
Sense Qual: 0x02
unfortunately i'm not enough of an expert to understand exactly what's going on in there. :(
Postby skandaluz on Tue Dec 30, 2003 8:20 pm
Yes, i'm tryin to burn data. I'm using the Lead data cd-r's because i got the really cheap at fry's electronics when i was in dallas. It was like $4.50 for a 50 pack so i bought it. I'll uninstall the nvidia IDE drivers n see if that works. If not then i'll come back here n ask again, hehe.
skandaluz
