Digital-Audio Cable for DVR-108
Postby kinemax on Sun Oct 31, 2004 6:09 pm
Where can I get a cable to connect the DVR-108's 4-pin digital-audio terminal to the 2-pin digital-audio terminal of sound-cards such as the Audigy 2 ZS?
kinemax
Postby Ian on Sun Oct 31, 2004 6:46 pm
That 4 pin connector isn't a digital audio out. In fact, the drive doesn't support digital audio.
Postby kinemax on Sun Oct 31, 2004 8:31 pm
Thanks for the reply.
So what is that connector for? I had thought it was a digital-audio connector based on its description in this product review article.
kinemax
Postby Ian on Sun Oct 31, 2004 8:46 pm
Odd.. there are two little connectors on the left hand side of their drive. The blue one is normally on most Pioneer drives and is used for factory testing. But the white one is new and is not on the retail version of the drive (the A08) or the Pioneer clones I've seen. I'm guessing its there because they had an early engineering sample? Or maybe its because they use the same picture for both the Pioneer 108 and ASUS 1604P review?
Postby kinemax on Sun Oct 31, 2004 11:18 pm
You just answered my question: it's the blue connector in the review article's picture, which comes in white color in the production models as showed in this picture, that I was referring to.
kinemax
Postby hoxlund on Tue Nov 02, 2004 1:53 am
its nothing you'll need to worry about
besides why use those cables anyways, the audio cables i mean
Thermaltake Core X5 Snow Edition TG Case
Corsair RM1000 Power Supply
MSI X399 Gaming Pro Carbon AC
AMD Threadripper 1950x @ 4.1GHz
Custom Loop w/ EK MSI x399 Monoblock
G.Skill 4x8GB DDR4 3200 RGB Memory
MSI 1080Ti Lightning X Video Card
Postby frontman on Thu Jan 06, 2005 10:58 am
I was wondering about this drive myself.......if it doesn't have SPDIF on it then how do you get 5.1 playback out of this unit. Hoxlund said, "its nothing you'll need to worry about, besides why use those cables anyways, the audio cables i mean..." How is it Hoxlund that someone would be able get digital audio quality with a soundblaster ZS. How is your dvr-108 set up?
THX....
frontman
Postby cfitz on Thu Jan 06, 2005 11:38 am
Optical drives transfer the digital 5.1 audio over the same IDE cable as all the other digital data from the drive. Optical drives can also transfer 2-channel digital audio over the IDE cable. SPDIF is not needed for digital audio.
Postby hoxlund on Thu Jan 06, 2005 8:19 pm
thx cfitz you beat me, stupid staples, i was at work all day
Postby frontman on Thu Jan 06, 2005 8:54 pm
So if I get a soundcard I can hook up the drive to the motherboard with the IDE cable and get 5.1 audio with no cables going into the soundcard at all?
THX..
frontman
Postby Ian on Thu Jan 06, 2005 9:34 pm
Yup, that's what he's saying. Just make sure that your DVD playback software supports 5.1. A lot of the bundled stuff only does 2 channel.
Postby cfitz on Thu Jan 06, 2005 10:24 pm
hoxlund wrote:thx cfitz you beat me, stupid staples, i was at work all day
No problem. At least it pays the bills, right?
Postby hoxlund on Fri Jan 07, 2005 12:57 am
yeah just don't use those audio cables I honostly don't know why they still include them in the boxes of drives
Postby frontman on Sun Jan 09, 2005 8:58 am
Thx for the replies guys........Do you know if Nero Showtime supports DD5.1...and that this should work with a SBA ZS and IDE cable only...?
frontman
Postby cfitz on Sun Jan 09, 2005 11:38 am
frontman wrote:Do you know if Nero Showtime supports DD5.1
Showtime does support Dolby Digital 5.1, but you have to pay extra to enable it for some versions. It's been a while since I looked at Nero and I won't attempt to explain (or even understand) their product differentiation strategy, but suffice it to say that there are differences between European/American/international versions and OEM/retail versions. Some require purchase of an additional plug-in to enable the 5.1 support. If you have the full-retail American version, I'm pretty sure 5.1 is already enabled.
