Hard Drive Issue
Hard Drive Issue
Postby Spazmogen on Tue Nov 07, 2006 7:13 pm
My Western Digital EIDE 160gb drive now apears in XP as 128GB, not the usual 149gb it usually was. Its a secondary drive, used for storage only. Its not bootable.
I had Norton GoBack installed and then removed it. I have a gut feeling that GoBack has altered my drive somehow.
I've tried fdisk, but it says that there are no more partitions on it.
I've also tried partition Magic, same thing: 128mb
Any ideas how I can get the missing GB's back?
Postby redk9258 on Tue Nov 07, 2006 8:55 pm
You could download software from their website (http://support.wdc.com/download/index.asp?cxml=n&pid=999&swid=1) and zero fill the hard drive. This should make it as if it was new. Did something on your motherboard's bios change?
redk9258
Postby Spazmogen on Tue Nov 07, 2006 9:28 pm
I had a copy of Data Life Guard 10 (with 0's ability). I did that.
The Data Life Guard sees the drive as 149GB.
I did update the BIOS to F7 for the motherboard.
Perhaps I'll try FDISK again now that I've done the zero fill.
Postby Spazmogen on Tue Nov 07, 2006 9:43 pm
thanks redk9258.
You got me thinking down another line, which solved the problem:
Update the driver on the ATA100 card.
Worked like a charm. The drive was attached to directly to my MB in the last system. In this build, I had to put it on the ATA100 card.
I was going at the problem by trying out the difficult stuff 1st (BIOS settings, XP Registry settings etc).
Postby redk9258 on Wed Nov 08, 2006 8:33 am
Glad you got it! Have you found WD to be reliable? I have one that the bearings went bad on. It was replaced under warranty. The replacement seems to be holding up OK. I have had good luck with Maxtor drives. Some people say they aren't reliable either. I guess all brands can fail and the people who say X brand is no good had one fail while thousands of other people have no problems.
redk9258
Postby Spazmogen on Wed Jan 10, 2007 9:35 pm
lol. Murphy's Law.
The Wd 3 year warranty ended on Dec 25th.
The drive has just now developed a loud squeal, and seldom runs.
I tried it in the external USB 2.0/Firewire case and it still does it.
1 dead drive.
Good thing I pick up my 250gb SATA2 drive next week in Florida.
