How do i strip/rip an Audio DVD ?
Postby xboxnoob on Thu Jan 29, 2004 10:13 pm
Anyone got the idea of how to strip the audio from a Audio dvd ?
all the audio is actually in the Audio_ts folder it's not empty longer .)
But all rippers out there - only care for the movie/audio files in Video_ts
T.I.A.
John -DK
When everything's coming your way, you're in the wrong lane.
xboxnoob
Postby burninfool on Thu Jan 29, 2004 10:59 pm
Postby xboxnoob on Fri Jan 30, 2004 6:58 am
Cheers m8
That i will try - because - its not all the disk i want - i want a few numbers from several disks - so i can make my own cmpilation..
thx again
xboxnoob
Postby hilander on Sun Feb 22, 2004 12:15 pm
Just found this: DVD Audio Ripper www.imtoo.com
Not freeware, but works great and is quick.
Another way would be to rip the DVD with Smartripper, change audio to 2 channel AC3 and then use Head3ache to convert the audio file to WAVor MP3.
Check out the digital digest forums for more detailed info.
hilander
Postby xboxnoob on Sun Feb 22, 2004 2:13 pm
Hi Hilander.
Ill try that - or else i have to settle for whole disk
Cheers
John
Denmark
"Experience is something you don't get until just after you need it."
xboxnoob
Postby burninfool on Sun Feb 22, 2004 4:41 pm
"DVD Audio Ripper" is for DVD-Video discs not DVD-Audio,DVD-Video uses CSS encryption and DVD-Audio uses CSS2 encryption.
Postby xboxnoob on Sun Feb 22, 2004 7:16 pm
Jups..
Have not found anything to Rip an Audio Dvd yet.....
Bummer
Cheers
John
Denmark
xboxnoob
Postby NoSmartz on Tue Feb 24, 2004 3:13 pm
Soren Kierkegaard
NoSmartz
Postby xboxnoob on Tue Feb 24, 2004 3:55 pm
Okay - here we go trying again...
But i will soon give up, because of the way Audio DVD are built..
All info i Audio_TS folder. - and different decryption.
But i'll try this proggy too..
Cheers
John
Denmark
xboxnoob
