i need help please
i need help please
Postby gaara17 on Mon Sep 20, 2004 1:44 am
i have roxio cd/dvd burner but when i tried to burn a anime show to a dvd/R it says somthing like dvd recorder not found... :o
what should i do :-k
gaara17
Postby dodecahedron on Mon Sep 20, 2004 3:00 am
we need some more info in order to help you out.
which Roxio software do you have? version number?
operatin system of your computer?
what DVD recorder are you using? what firmware does it have?
what exactly are you trying to burn? how?
Postby gaara17 on Mon Sep 20, 2004 7:53 pm
dodecahedron wrote:we need some more info in order to help you out.
roxio easy cd creator 5.3.4. sp8 basic
windows xp
it says that i dont have a dvd recorder
iam trying to burn Naruto a anime show , by using roxio on a dvd/r.
gaara17
Postby Ian on Mon Sep 20, 2004 9:02 pm
That is a fairly old version. You could try downloading an update form Roxio, but I'm guessing you're probably going to need a newer version like 6 or 7.
What drive do you have?
Postby dodecahedron on Tue Sep 21, 2004 3:35 am
the latest version of Easy CD Creator 5 basic is 5.3.5.10. you can update from Roxio's website, support section.
be sure to get the latest drive database file, to be sure your drive is recognized.
the last time i checked it was DriveUp5.3.5t.exe, but there may be a newer version already.
what is you DVD recoreder?
on second reading of Ian's response, i'm not even sure that ECDC 5 basic can burn DVDs ! ??? :o
