Nero CD-DVD Speed -create disc problem
Postby callous on Fri Jul 08, 2005 4:56 pm
There was a time when I would select create disc and it would random create files to fill up the entire dvd so that I can test the dvd media.
Now if i select create disc, it'll ask me to select a .nrg image.
How do i get this program to auto create random files on the dvd without me selecting a .nrg image
callous
Re: Nero CD-DVD Speed -create disc problem
Postby TCAS on Fri Jul 08, 2005 6:02 pm
callous wrote:There was a time when I would select create disc and it would random create files to fill up the entire dvd so that I can test the dvd media.
If the version of Nero CD/DVD Speed you are using does not support your drive (DVD-RW) then you would face this situation.
Postby callous on Fri Jul 08, 2005 6:13 pm
It's happening with dvd+rw and dvd-rw so that cant be it
callous
Postby dodecahedron on Sat Jul 09, 2005 12:03 am
in Options -> Standard Tests -> Transfer Rate, make sure Burn Image File checkbox is unchecked.
Postby callous on Sat Jul 09, 2005 12:41 am
Ah, that and removing generate data or someting like that fixed it.
Thanks a lot!
callous
Postby dodecahedron on Sat Jul 09, 2005 2:12 am
welcome :)
it's "Include test data" and you don't have to remove it, you can leave that checkbox checked, it will still burn random data not an .nrg file. it will save a copy of the burn scan on the disc.
