Plextor 708A Burning problems
Postby deftonie on Sun Sep 12, 2004 2:20 pm
Hello,
I am having a problem with burning a CD-R. I am using Nero 6.3.1.20. Once I start to burn the CD I recieve little or none Used Read Buffer. Its taking a good hour to burn an ISO. Any help or suggestions would be much appreciated.
Sincerely, Deft
deftonie
Postby babar on Sun Sep 12, 2004 7:10 pm
set it on fire
or try a different burner
shuttle sb61g2
2.53ghz piv
seagate barracuda v serial ata 120gb
samsung sm-348b t511 firmware
plextor px-708a 1.01 firmware
512mb corsair xms2700
win xp professional
babar
Postby dodecahedron on Mon Sep 13, 2004 3:17 am
make sure DMA is enabled.
for instructions on how to do that, check the FAQ
Postby vsekh on Mon Sep 13, 2004 11:25 am
Also, make sure you have upgraded your burner to the latest firmware available.
vsekh
Postby deftonie on Mon Sep 13, 2004 5:17 pm
DMA was enabled. My firmware was updated to latest before posting. It didnt fix the problem :cry: . Would having my local Disk F: not C: make this happen? This is the first time I have tried to burn anything after installing Windows XP Pro Service Pack 2.
Sincerely, Deft
deftonie
Postby vsekh on Mon Sep 13, 2004 5:47 pm
What brand of CD-R are you using and it's rated speed?
vsekh
Postby deftonie on Mon Sep 13, 2004 8:57 pm
Brand: Memorex Speed:40x But was using all speeds to see if it was rated wrong. I still had the problem.
deftonie
Postby Scour on Tue Sep 14, 2004 4:13 am
Is DMA enabled with your Plextor and the HDD?
What´s your configuration (Primary/secondary master)?
Which mainboard do you have?
Postby deftonie on Tue Sep 14, 2004 3:55 pm
Windows XP Pro SP2
K7N2 Delta-ILSR
Bios Version 7.8
AMD Athlon 2500+
1x512 Kingston 2700
PowerColor Radeon 9600 Pro 256 MB
Primary Master: Seagate Barracuda 200 GB
Primary Slave: Maxtor 40 GB
Secondary Master: Plextor 708A 1.07 Firmware
3 1/2 Floppy
Power Supply: +3.3V 32A, +5V 40A, +12V 24A
All drives have DMA enabled.
deftonie
Postby vsekh on Tue Sep 14, 2004 5:25 pm
If you're motherboard uses an nforce chipset, try using the default windows drivers instead of using the Nvidia IDE drivers.
vsekh
