Plextor PX-716A Problem
Postby refnex on Tue Apr 12, 2005 2:53 am
Hallo #-o Ich habe eine problem mit meine Plextor :evil:
wen die UDMA4 activiert sind unter WinXP der Plextor liest keine CD oder DVD`s wo ist der feller??oder was mache ich falls? :(
danke im voraus
Thank you very much
and sorry for my English :)
refnex
Postby CowboySlim on Tue Apr 12, 2005 11:13 am
zehn-vier
Postby hoxlund on Tue Apr 12, 2005 12:28 pm
english please
ive gathered that there is a udma problem under windows xp
Postby CowboySlim on Tue Apr 12, 2005 1:07 pm
CowboySlim wrote:zehn-vier
10-4
Postby refnex on Wed Apr 13, 2005 4:43 am
ok sorry Now in English
when my UDMA4 active is My PLEXTOR px-716A dont play any CD`s or DVD`s
I change the Cables and now is windows sees UDMA2 but Plextor is working normal wher is the mistake??
Thank you very much
refnex
Postby hoxlund on Wed Apr 13, 2005 12:20 pm
make sure your using udma 4 capable cables, they have twice as many wires in them
and in the bios make sure dma is turned on
one more thing you can try is deleting the drive in device manager then restart windows
Postby bob11879 on Thu Apr 14, 2005 6:31 pm
If it works normal with UDMA2, could be a timing issue between the drive and your chipset (or drivers). UDMA2 is still fast enough for 16x write, though CRC errors may happen occassionally at the faster rate on some systems.
bob11879
