Startsmart won't stay open
Postby tibpol on Wed Jun 02, 2004 10:33 am
Hi,
I just installed the demo version. When I try to open startsmart it pops up than shuts down immediately, won't stay open.
I reinstalled it two times, didn't help. Any suggestion?
Thank you,
tibpol
tibpol
Postby CCampbell on Wed Jun 02, 2004 12:14 pm
Do you only have trouble with the StartSmart?
IF you go to Start->Programs->Nero, are you able to launch Nero Burning ROM/Nero Express or any of the other programs from there, and do they remain open or close as Nero StartSmart does?
It sounds like a failed install. Did you install from a download off our website, or off the CD?
I would recommend useing the Nero Clean tool on our website @
http://www.nero.com/us/631940828445001.html
to uninstall our software, ANd then do a fresh download of our latest release and reinstall to see if this resolves your issue.
Postby tibpol on Wed Jun 02, 2004 2:44 pm
Thank You, Craig
I followed your instruction. It didn’t work.
I’m able to open Nero Burning ROM/Nero Express. I have no trouble.
I’m trying to install it on XP Pro
tibpol
tibpol
Postby pranav81 on Thu Jun 03, 2004 1:47 am
I had faced the same problem with Nero 6.0.3.X.Only difference was that I was not able to open Nero Express or Nero Burning ROM also.
When I installed 6.3.X.X the problem was gone.I still use 5.5 as I dont think I need Nero 6 at this moment.
::Pranav::
pranav81
Postby pranav81 on Thu Jun 03, 2004 1:51 am
BTW, which version do you use?
::Pranav::
pranav81
Postby tibpol on Thu Jun 03, 2004 7:13 am
6.3.1.15 Demo
tibpol
tibpol
Postby pranav81 on Fri Jun 04, 2004 1:50 am
You could try installing an older version.It may or may not work.
::Pranav::
pranav81
