Newbie needs Help with DVD Burning
Postby rkunderhill on Fri Sep 02, 2005 8:33 pm
Hi, I am a newbie when it comes to DVD burning and setting up the software to do what I want. I need some instruction please.
I got my DVD burner yesterday, and some DVD+R DL. I got the DVD burner set up, burned two disks, They work fine in the burner, but when I put them in my main DVD/CD-RW, they won't register.
Here is my equipment, media and software
DVD+/-RW 16x+|NECND-3520A BG - OEM - (external) USB 2.0 connection
QSI CDRW/DVD SBW242C - (internal) came with computer
Media: RiDATA, Double Layer DVD+R DL 2.4x
Software: Nero Ulta 6.6
Can anyone help me with this problem? I am going crazy. I want to be able to burn the DVD, then read them in my DVD Rom in my computer.
I have no problem reading other DVD's from other burners.
When burning I am creating a mutli session if that makes a difference.
Thanks for your help.
I went back later and copied the DVD's and on the copy I closed the session, however, My DVD-Rom, CD-rw still won't read that one.
Robin K. Underhill
rkunderhill
Postby Ian on Fri Sep 02, 2005 9:20 pm
Does your DVD-ROM even support the DVD+R DL format?
Are the discs readable in the drive that burned them?
What happens if you don't use multisession?
Postby rkunderhill on Fri Sep 02, 2005 9:28 pm
Yes my DVD RW supports the DVD+R DL
They are readable in the drive I burn them from.
When I didn't use multisession, I can read the disk in the drive I burned from, but could not read in the drive in the computer.
Robin K. Underhill
rkunderhill
Postby Ian on Fri Sep 02, 2005 9:47 pm
Yes, your DVD RW supports DVD+R DL.. but that doesn't mean that the drive in your computer does.
Postby rkunderhill on Fri Sep 02, 2005 9:57 pm
According to the Nero Info tool, the drive in my computer does support DVD+R DL for reading. Is there anyother way to find out for sure? Could I be burning the disk wrong or could it be the disk itself? What other information do you need?
Robin K. Underhill
rkunderhill
Postby dodecahedron on Sat Sep 03, 2005 2:56 am
the media you are using is RiDATA (=made by Ritek), not the best media there is. their DL isn't very good.
Postby Scour on Sat Sep 03, 2005 7:53 am
Like dodecahedron wrote, Ritek DL-media is not good, maybe the crappiest DL-media you can get.
The NEC 3520 sets the booktype of +R DL-media automatically to DVD-ROM, I guess. This should make the media readable for most drive.
With Cdspeed you can make a disc-quality-test of your media.
www.cdspeed2000.com
Postby burninfool on Sat Sep 03, 2005 2:06 pm
1.What OS are you using?Only 2000/XP support multi-session.
2.Update the firmware of your drives at www.rpc1.org
3.Use DVDDecrypter(in ISO Mode) or RecordNow Deluxe to burn.
Postby rkunderhill on Sat Sep 03, 2005 2:33 pm
burninfool wrote:1.What OS are you using?Only 2000/XP support multi-session.
I have xp. My problem was the media. So thanks for help on that.
But now I am having a problem recording Movies. I downloaded DVDshrink, I got the movie saved on my harddrive, then when I went to burn (I bought new DVDs, Maxell and Memorex), could not find Verbatium. Do I need to download DVDDecrypter to burn backups of my DVD movies? I have right now Nero Ultra 6.6 and DVDShrink. I just don't know exactly what to do, or how to do it, This is all brand new to me.
Robin K. Underhill
rkunderhill
Postby burninfool on Sat Sep 03, 2005 6:58 pm
You can download DVDDecrypter here:
www.mrbass.org/dvdrip/
In DVDShrink when you backup it will ask you what you want to do,choose "make an ISO and burn with DVDDecrypter".
BTW...if you're using DL go to Preferences and select DVD-9 for target.
Postby rkunderhill on Sat Sep 03, 2005 8:40 pm
Thanks so much for your help. I was going a little crazy trying to figure this out. :D
Robin K. Underhill
rkunderhill
Postby ETP on Sun Sep 04, 2005 6:45 pm
BQ 1640 BSOB
NEC 4550 1.6T
Plextor 716a 1.09
Pioneer 109/A09 158
Pioneer 110/A10 1.39
Liteon 5005
Sony 875P & 333ES
Liteon 5005
HK7200
Hitachi 61SDX
ETP
