Problem with my Pioneer DVR-107D
How fast is too fast?
Postby joel_taiwan on Fri Jan 28, 2005 1:35 pm
This is my first post, and judging by some of the responses here, this is a great forum. I hope someone out there can help me with my problem.
My DVD-R (Pioneer DVR-107D) has been working fine for about 6 months until tonight it suddenly stops recognising DVDs, both blank and real ones. I can't burn, I can't get anything showing up.
I saw a recent post that had a similar, but not identical problem.
I use WinXP Pro. My Computer shows the drive there, well enough. But as I say it doesn't recongise any DVDs. What it DOES do is to recognise CDs and is able to burn CDs no problem.
This is where the difference lies. I don't know much about hardware admittedly, but if its recognising CDs and not DVDs I doubt that its a cable problem.
Any suggestions? Please reply either here, my email, or I use Yahoo Messenger and MSN as well.
Thanks so much in advance. This is actually the second time this has happened to me. The first time I just went and bought a new one. I want to avoid that if possible.
Joel.
joel_taiwan
Postby Scour on Fri Jan 28, 2005 5:42 pm
Helloo!
Maybe the DVD-lens is defect or dirty. The CD-lens is not the same lens, so it can be that the CD-section works and the DVD-section not
Postby hoxlund on Sat Jan 29, 2005 11:27 am
see if removing it from the device manager works
it should re-recognize it and set it up again
also make sure DMA is turned on
but of course these are software fixes, your problem is suggesting a hardware issue
if all else fails, just stand in front of your drive with a long coat on and then open your front and flash it #-o :
http://forum.rpc1.org/dl_firmware.php?download_id=1754
Postby Scour on Sat Jan 29, 2005 8:32 pm
Can you test the drive in an other PC?
Postby joel_taiwan on Sat Jan 29, 2005 11:13 pm
Hey Guys,
Thanks for the tips.
1) Tried a lens cleaner. Didn't work.
2) Also tried removing it from Device Manager and reinstalling. Still the same. Checked DMA - enabled.
3) I only have the one computer
4) It makes this loud clicking sound now when either accessing a CD (successfully) and trying to access a DVD (never successful).
What could be wrong?
Normally, I'd take it to the shop and ask them to fix it, but I'm in Taiwan and my chinese ain't good.
Any other clues or tips? Is this a common problem? This has happened to me with another model before.
Joel.
joel_taiwan
Postby hoxlund on Sun Jan 30, 2005 11:51 am
well it does sound like a broke drive, if it clicks that is
Postby joel_taiwan on Sun Jan 30, 2005 1:23 pm
Well thanks for the tips guys. I came to the conclusion the drive was stuffed, so I coughed up the dough for a new one.
Pioneer DVR-109 (Double Layer DVD+-R)
Hope this one doesn't )#&$)#& up on me.
Joel.
joel_taiwan
