Problems burning DVD+R DL disc
Postby PaulAlex7000 on Sat May 28, 2005 1:13 am
The Nero History Log file is below.
Basically, trying to get a Pioneer A10 to burn data to Verbatim DVD+R DL disc. I thought I was getting farther in it burning a non-multi-session disc, but no dice.
Any ideas on this one? Thanks!
Code: Select all
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.13
Internal Version: 6, 6, 0, 13c
Recorder:             <PIONEER DVD-RW  DVR-109> Version: 1.40 - HA 0 TA 0 - 6.6.0.13
Adapter driver:      <atapi>                   HA 0
Drive buffer  :      2000kB
Bus Type      :      default (0) -> ATAPI, detected: ATAPI
CD-ROM:               <PIONEER  DVD-RW  DVR-109 >Version: 1.40 - HA 0 TA 0 - 6.6.0.13
=== Scsi-Device-Map ===
CdRomPeripheral      : PIONEER DVD-RW  DVR-109          atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : PLEXTOR CD-R   PX-W2410A         atapi Port 1 ID 0  DMA: On
DiskPeripheral       : WDC WD2000JB-00DUA0     70.1    hpt3xx Port 2 ID 0  DMA: Off
DiskPeripheral       : WDC WD2000JB-00DUA0     70.1    hpt3xx Port 2 ID 1  DMA: Off
OtherPeripheral      : ADAPTEC RCM DEVICE              hpt3xx Port 2 ID 0  DMA: Off
DiskPeripheral       : Promise 1+0 Stripe/RAID01.10  fasttx2k Port 3 ID 0  DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW  DVR-109    Y:   CDRom0
PLEXTOR CD-R   PX-W2410A   X:   CDRom1
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 1023MB (1048020kB)
Free physical memory: 257MB (263500kB)
Memory in use       : 74
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
27.5.2005
ISO compilation
9:18:24 AM   #1 Text 0 File Isodoc.cpp, Line 6194
   Iso document burn settings
   Simulate                : FALSE
   Write                   : TRUE
   Finalize CD             : TRUE
   Multisession            : FALSE
   Burning mode            : DAO
   Mode                    : 1
   ISO Level               : 1 (Max. of 11 = 8 + 3 char)
   Character set           : ISO 9660
   Joliet                  : TRUE
   Allow more than 255 characters in path  : FALSE
   Write ISO9660 ;1 file extensions        : TRUE
9:18:24 AM   #2 Text 0 File Reader.cpp, Line 127
   Reader running
9:18:24 AM   #3 Text 0 File Writer.cpp, Line 122
   Writer PIONEER  DVD-RW  DVR-109  running
9:18:24 AM   #4 ISO9660GEN -11 File geniso.cpp, Line 3293
9:18:29 AM   #5 Text 0 File Burncd.cpp, Line 3167
9:18:30 AM   #6 Text 0 File DlgWaitCD.cpp, Line 260
   Last possible write address on media:  4173823 (927:30.73, 8151MB)
   Last address to be written:            4041823 (898:10.73, 7894MB)
9:18:30 AM   #7 Text 0 File DlgWaitCD.cpp, Line 272
9:18:30 AM   #8 Text 0 File DlgWaitCD.cpp, Line 2339
   Recorder: PIONEER DVD-RW  DVR-109, Media type: DVD+R9 Double Layer
    Disc Manufacturer ID: MKM, Media Type ID: 001, Product revision number: 0
    Disc Application Code: 0, Extended Information Indicators: 0
9:18:30 AM   #9 Text 0 File DlgWaitCD.cpp, Line 438
9:18:30 AM   #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
    0: TRM_DATA_MODE1 ()
       original disc pos #0 + 4041824 (4041824) = #4041824/898:10.74
       -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4041824 blocks [PIONEER  DVD-RW  DVR-109]
9:18:30 AM   #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
   Prepare recorder [PIONEER  DVD-RW  DVR-109] for write in CUE-sheet-DAO
   DAO infos:
    MCN: ""
    Tracks 1 to 1:
      1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    8277655552, ISRC ""
   DAO layout:
          0 |  lead-in |   0 |    0x41 | 0x00
          0 |        1 |   0 |    0x41 | 0x00
          0 |        1 |   1 |    0x41 | 0x00
    4041824 | lead-out |   1 |    0x41 | 0x00
9:18:30 AM   #12 Phase 24 File dlgbrnst.cpp, Line 1832
   Caching of files started
9:19:13 AM   #13 Text 0 File Burncd.cpp, Line 4051
   Cache writing successful.
9:19:13 AM   #14 Phase 25 File dlgbrnst.cpp, Line 1832
   Caching of files completed
9:19:13 AM   #15 Phase 36 File dlgbrnst.cpp, Line 1832
   Burn process started at 2.4x (3,324 KB/s)
9:19:14 AM   #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
9:19:14 AM   #17 Text 0 File DVDPlusDualLayer.cpp, Line 430
   Disc finalized, LBA total Image size: 4041824 (7894MB), Last LBA L0: 2020927 (3947MB)
9:19:37 AM   #18 SCSI -1066 File Cdrdrv.cpp, Line 1182
   SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x0C320600
   Status:     0x04 (0x01, SCSI_ERR)
   HA-Status   0x00 (0x00, OK)
   TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
   Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
   Sense Code: 0x24
   Sense Qual: 0x00
   CDB Data:   0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x21 0x08 0x04 0x00 0x00
   Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
               0x00 0x00 0x00 0x00 0x24 0x00
9:19:37 AM   #19 Text 0 File DVDPlusDualLayer.cpp, Line 519
   L0 Data Zone Capacity set to 2020928 (1ED640h, 3947MB) -> OK, confirmed setting
9:19:37 AM   #20 CDR -1205 File DVDPlusDualLayer.cpp, Line 544
   Burning Layer 1
9:19:37 AM   #21 Text 0 File DVDPlusDualLayer.cpp, Line 552
   Start writing layer 1 at address 0 (0h)
9:19:37 AM   #22 Text 0 File Cdrdrv.cpp, Line 8438
    Book Type: DVD+R DL (14), Part Version: 1
    Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
    Number of Layers: 2,    Track Path: Opposite Track Path (OTP),  Layer Type: recordable
    Linear Density:         0,293 um/bit,  Track Density:  0,74 um/track
    End Physical Sector Number of Data Area:      FCFFFF h
    End Sector Number in Layer 0:                 21D63F h (LBN: 1ED63F h, 3947 MB)
     Disc Application Code: 0 / 0 h
     Extended Information indicators: 0 h
     Disc Manufacturer ID: MKM.....
     Media type ID: 001
     Number of Physical format information bytes in use in ADIP up to byte 63: 64
    Media Specific [16..63]:
         00 00 00 4D 4B 4D 00 00 - 00 00 00 30 30 31 00 40    ...MKM.....001.@
         25 25 37 0C 02 2F 63 02 - 2F 63 21 23 0D 0E 14 14    %7../c./c!#....
         02 01 01 10 00 21 23 0D - 0E 14 14 02 01 01 10 00    .....!#.........
9:19:37 AM   #23 Text 0 File DVDPlusRW.cpp, Line 652
   Start write address at LBA 0
9:19:40 AM   #24 Text 0 File Cdrdrv.cpp, Line 1288
   09:19:40.984 - PIONEER DVD-RW  DVR-109\H0 T0 : Queue again later
9:19:41 AM   #25 Text 0 File Cdrdrv.cpp, Line 1288
   09:19:41.796 - PIONEER DVD-RW  DVR-109\H0 T0 : Queue again later
9:19:42 AM   #26 Text 0 File Cdrdrv.cpp, Line 1288
   09:19:42.609 - PIONEER DVD-RW  DVR-109\H0 T0 : Queue again later
9:19:43 AM   #27 Text 0 File Cdrdrv.cpp, Line 1288
   09:19:43.234 - PIONEER DVD-RW  DVR-109\H0 T0 : Queue again later
9:21:21 AM   #28 SCSI -1135 File Cdrdrv.cpp, Line 1436
   SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03E60000
   Sense Key:  0x03 (KEY_MEDIUM_ERROR)
   Sense Code: 0x0C
   Sense Qual: 0x00
   CDB Data:   0x2A 0x00 0x00 0x02 0x78 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
   Sense Data: 0x71 0x00 0x03 0x00 0x02 0x75 0xF0 0x0E
               0x00 0x00 0x00 0x00 0x0C 0x00
9:21:21 AM   #29 CDR -1135 File Writer.cpp, Line 311
   Write error
9:21:21 AM   #30 Text 0 File ThreadedTransfer.cpp, Line 228
9:21:21 AM   #31 Text 0 File ThreadedTransfer.cpp, Line 222
9:21:26 AM   #32 Phase 127 File dlgbrnst.cpp, Line 1832
   Generating DVD high compatibility borders
9:21:46 AM   #33 CDR -1122 File WriterStatus.cpp, Line 167
   Unable to recover TOC
9:21:46 AM   #34 TRANSFER -24 File WriterStatus.cpp, Line 167
   Could not perform end of Disc-at-once
9:21:46 AM   #35 Phase 38 File dlgbrnst.cpp, Line 1832
   Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 10:59:44 PM (Adapter driver for rec)
Registry Keys:
====== *** Nero-Burning Rom, History File *** ======
PaulAlex7000
Postby Bhairav on Sat May 28, 2005 2:24 am
Why is DMA off on your HDDs? Enable DMA.. pretty sure that's your problem.
Postby PaulAlex7000 on Sat May 28, 2005 3:03 am
Bhairav wrote:Why is DMA off on your HDDs? Enable DMA.. pretty sure that's your problem.
I'm not sure how to enable it -- the hard drives in question are connected to an Adaptec 1200 RAID IDE card. And neither the "SCSI" device or the disk drives themselves in the Device Manager give an option for DMA.
PaulAlex7000
Postby Boba_Fett on Mon May 30, 2005 3:20 pm
With non-native HDD methods (PCI cards, 3rd party chips not integreted into the mobo's Southbridge), Windows always recognizes optical and hard drives as SCSI. I have no clue as to whether there is a performance hit there since you don't have any DMA options...
eVGA NF4 SLI mobo
2GB Mushkin DDR PC4000
Pioneer 111D 16x DVD burner
Onboard Sound :(
Boba_Fett
Postby PaulAlex7000 on Tue May 31, 2005 11:41 pm
Come to think of it, if it was an issue with DMA, shouldn't I be seeing problems when it comes to burning a single layer DVD+R disc. Or DVD-RW (in ISO format, not UDF).
I'm not good at reading the Nero error logs, but it seems it's having an issue with the second layer?
PaulAlex7000
Postby dodecahedron on Wed Jun 01, 2005 1:59 am
PaulAlex7000 wrote:Come to think of it, if it was an issue with DMA, shouldn't I be seeing problems when it comes to burning a single layer DVD+R disc. Or DVD-RW (in ISO format, not UDF).
probably, if you were burning at 8x.
did you try Nero InfoTool (Configuration tab) ?
what does it say about DMA mode of the drives attached to the Adaptec IDE card ?
Postby unclebud on Wed Jun 01, 2005 9:30 pm
my sympathies to op
unclebud
Postby PaulAlex7000 on Thu Jun 02, 2005 5:40 am
I was burning the DVD+R discs at 4x, so probably no chance of buffer underrun.
The Verbatim DL disc I was attempting to burn at 2.4x.
dodecahedron wrote:did you try Nero InfoTool (Configuration tab) ?
I launched it, and it did not say either way (DMA on or off) about the hard drives attached to the Adaptec card. It did say that DMA was on for both my Plextor CD and Pioneer DVD burner.
For what it's worth, looks like the Adaptec 1200A uses the Highpoint chipset, since the drivers being used are hpt3xx.sys.
Plextor is master on primary, and Pioneer is master on secondary channel (the main hard drive -- with the OS -- being a SATA drive attached to a Promise onboard controller).
PaulAlex7000
Postby CCampbell on Fri Jun 03, 2005 1:48 pm
The log file shows three errors.
THe first one comes as soon as it looks at the media, and reports a "KEY_ILLEGAL_REQUEST". And then it moves on and when our software issues it's first 'WRITE' command, the Recorder reports a 'Queue Again Later' error message, which means the recorder is busy and not accepting commands. It never recovers from being busy, so it's not accepting commands, and it times out with the "KEY_MEDIUM_EOR" message.
Do you have the latest firmware for your recorder? Have you tried different DVD DL media?
Regards
Postby PaulAlex7000 on Fri Jun 03, 2005 6:30 pm
CCampbell wrote:The log file shows three errors.
Hi Craig... I'm using firmware 1.5 (the newest), but had originally tried it on firmware 1.40.
I haven't tried any other DL media yet. What I'm using presently is the Verbatim 2.4x DL, purchased at CompUSA. And I bought two more 3-packs from Newegg.com, which I haven't tried yet.
I jumped the gun by buying this many Verbatim media because so many people said they didn't have any problems with Verbatim, and it's the only supported media by Pioneer that will burn at 6x DL (although I haven't tried that fast of a speed yet).
PaulAlex7000
