Trobule with sony crx120e
Postby edsqu on Fri Dec 27, 2002 6:30 pm
My Burner keeps crapping out during a burn..in the past 20 cd's ive gotten aobut 3 to burn..it like shuts down mid way.. the burner just stops.I'm not savy at all with this..any sugestions?
Ive used real player, nero, "easy audio cd burnerr"
I cant figure it out
if u can help please do!
ed squ
icq:15954793
edsqu
Postby coolestnitish on Fri Dec 27, 2002 6:41 pm
Only reason I can think of is something wrong with power supply. Does it always stop at the same percent of burn or after same amount of time or periodically?
OH BEHAVE!!!!!
coolestnitish
hmm
Postby edsqu on Fri Dec 27, 2002 6:47 pm
i think it may...
im not exactly sure.
how would i fix that if that is the problem
edsqu
Postby coolestnitish on Fri Dec 27, 2002 7:06 pm
Fix a power supply problem? Get a new one. They aren't that expensive for the normal PC...
Have you been having problems with other peripherals on the PC too?
OH BEHAVE!!!!!
coolestnitish
Postby edsqu on Fri Dec 27, 2002 7:45 pm
nah
just this..
edsqu
Postby coolestnitish on Fri Dec 27, 2002 8:02 pm
Try copying a full CD onto a hard drive with that drive and see if it stops in the middle of it or copies it completely.
OH BEHAVE!!!!!
coolestnitish
Postby edsqu on Fri Dec 27, 2002 8:18 pm
copying cd to harddrive worked fine.
edsqu
Postby coolestnitish on Fri Dec 27, 2002 9:02 pm
When was the last time this burner worked properly on your system? If it worked fine before, what were the last software and hardware changes you did to the system? Isn't this a really old burner? Might even be it's coming to the end of its life.
OH BEHAVE!!!!!
coolestnitish
Postby edsqu on Fri Dec 27, 2002 10:38 pm
i got it in 2000.
it burned well...like hmmm 3 months ago
edsqu
Postby coolestnitish on Fri Dec 27, 2002 10:59 pm
Check if DMA is enabled on the drive. You can find the instructions for that in the FAQ section of these forums. If DMA is enabled, switch to PIO Mode and see if you still get same results. If PIO Mode is enabled, then switch the drive to DMA and then give it a try. I really am at a loss about your problem and can't think about anything else. Did you try different media? You already mentioned different software, so I'm just :-? Sorry can't think of anything else, I'll let some other members share their knowledge
OH BEHAVE!!!!!
coolestnitish
Postby edsqu on Fri Dec 27, 2002 11:28 pm
thanks for all your help!
your rad!
edsqu
