What is your Idle temp for P4 2.4Ghz and up?
Postby ryus on Fri Sep 12, 2003 11:46 pm
Just wanted to know what the norm should be. If I leave my comp on for over an hour, my idle temp is about 50 degrees C. If I play a game, with my 9800pro, my temp is around 60 degrees C.
Is this normal?
Thanks.
P4 3.0C, Abit IC7-MAX3, Antec True480W, Kingwin Aluminum case, 2X256 OCZ PC4000 Gold Edition,
Maxtor SATA 160GB, Maxtor 40GB ATA133
ATI 128mb Radeon 9800 Pro
Asus CD-S520, LiteON JLMS 166, Plexwriter48/24/48A, Pioneer 107
ryus
Postby tazdevl on Sat Sep 13, 2003 1:14 am
Pretty warm for a 2.4 assuming it isn't being overclocked. I've got a 2.6 @ 3.4 that idles @ 45 and 55 load. This is also with an abit board that typically indicates a higher temp than with other manufacturers.
I'd increase your case venitaltion, get rid of the thermal pad on the heatsink and use some decent thermal compound (Nanotherm PCM+ or Arctic Silver Ceramique) or get a new heatsink. Though the stock Intel heatsink actually has decent performance.
Might even want to do a combination of all 3.
Might also want to try reseating your heatsink.
RIG:
tazdevl
Postby ryus on Sat Sep 13, 2003 1:24 am
I have a Vantec AeroFlow, with Arctic Silver 3. Not sure if I applied the AS3 properly. It was my first time. But if I remember correctly, I think even with the stock fan I was gettin similar readings.
ryus
Postby TheWizard on Sat Sep 13, 2003 9:18 am
Good question, I haven't been able to check the temp of my P4 2.4GHz, I can't seem to find any hardware monitor for my Intel D845PEBT2.
No, I like women.
Postby Wedge Maniac on Sat Sep 13, 2003 12:51 pm
Intel Active Monitor won't work??
Wedge Maniac
Postby tazdevl on Sat Sep 13, 2003 2:14 pm
ryus wrote:I have a Vantec AeroFlow, with Arctic Silver 3. Not sure if I applied the AS3 properly. It was my first time. But if I remember correctly, I think even with the stock fan I was gettin similar readings.
You might not have adequate airflow in your case then. What size of case? How many fans? Fan locations?
If you put too much on, that would cause your temps to be higher than normal.
I'd try reseating the heatsink. Clean both off with isopropyl alcohol and let them sit for a couple minutes.
Put a small dallop on the bottom of the heatsink, wrap a finger in some plastic wrap smear it around, then wipe it off with a paper towel. Be sure there aren't any fibers from the paper towel on the heatsink. That will fill in any small grooves and ensure a good mechanical fit.
You want a very thin layer of AS3 on the core. On the CPU, same thing (small dallop, finger in plastic wrap) then use the edge of a razor or a plastic card to even it up.
FYI AS3 takes 2-3 days of running full time to settle in so a decrease in temps can take up to a week.
You can tell if you put too much AS3 on by looking @ the heatsink when you pull it off. If there's a lot around the imprint of the core on the bottom, that tells you to use less.
RIG:
tazdevl
Postby TheWizard on Sat Sep 13, 2003 4:49 pm
Wedge Maniac wrote:Intel Active Monitor won't work??
I actually haven't downloaded it yet...been too lazy. :D It's on my list of things to do now.
No, I like women.
Postby TidusTheCoolest on Sat Sep 13, 2003 7:04 pm
My P4 2.4b Ghz , have been OCed to 2.66 Ghz . It's idle temp is 42'c and full load temp is at 50'c . I'm using the stock heatsink .
AMD Athlon XP 3200+ , 512 PC2700 DDRAM , ATI Radeon 9600 Pro , 160 GB 7200 rpm 8 mb cache HDD
TidusTheCoolest
Postby black~cobra on Sat Sep 13, 2003 9:37 pm
with my new computer i get
--Mobo:34C
--CPU: 30C
My mobo is an asus p4p800dx and the "q-fan" thing is at 15/16 so the cpu fan rpm is running at 2600rpm thats why its only at 30C ..... If its on disabled or lower than 15/16 its running below 2000 rpm ... and 34C or more ....
Complete newbie to this stuff
black~cobra
Postby Morpheus on Sun Sep 14, 2003 5:59 pm
I have the 2.53Ghz P4 running at stock speed and an Asus motherboard. I use the Asus probe software and my cpu temp is almost always at 40 to 45 C. My motherboard temp used to be at 24-26C for the first few months when I got the motherboard but the last few months it has been in the 37 to 45C range which is weird.
Morpheus
Postby Alexandrus on Sat Sep 27, 2003 4:51 am
My idle temps on P4 2.4B are about 45C right now, but I have no case fans, no thermal paste between the CPU and cooler. I lapped both the CPU and cooler, mirror shine now, and I am still waiting for some Ceramique and a few Panaflo fans, but it seems my package is not being delivered :(
Oh yeah, the load temp goes above 60C.
Alexandrus
Postby texascbx on Sat Oct 18, 2003 8:36 pm
37c-p4 2.4c ecs648fx-a..thermaltake cooler,arctic silver
texascbx
