nu dual firmware is out
cd burning
Postby dvdevil on Sun Feb 29, 2004 6:43 am
Problems burning cd's with this firmware and it looks that i am not the only one...
dvdevil
? oooh
Postby tuxedomoon on Sun Feb 29, 2004 6:58 am
Oke possible?
flash upgrade from 362 to 364 won't work well, zo the best is to do it from 031 or the older 030 pro one to this latest 364.
Strange when you all mentioned cd burning sucks i started straight away burning cd's, no probs. use Platinum and Liftec cd and Philips RW.
copy onfly all kind off work good here
A thousand lives by picture
tuxedomoon
platinum
Postby dvdevil on Sun Feb 29, 2004 7:26 am
Upgraded from 031 this one wont burn platinum cd's not tested on the 364 firmware only silvercircle cd's 3cd's are coasters stops burning at 50 % (platinum 52x speed never worked on the Nu tech)
dvdevil
Re: platinum
Postby tuxedomoon on Sun Feb 29, 2004 10:14 am
dvdevil wrote:(platinum 52x speed never worked on the Nu tech)
Iám sorry but on my NU DDW-082 f/w 364 the PLATINUM 52x speed works :) Even audio extraction mp3 and backwards to cd audio burn at 26 speed ok. Yess iám zo happy as a little kid with his toy, believe me before this, it was terible and i throw a way many dvd and cd failures.
tuxedomoon
platinum
Postby dvdevil on Sun Feb 29, 2004 10:45 am
Did you burn platimum cd's with the old firmware......
dvdevil
Postby tuxedomoon on Sun Feb 29, 2004 10:55 am
No, only with the new 364 f/w.
tuxedomoon
Dual Layer
Postby gregdep on Thu Mar 04, 2004 7:07 pm
The US sales representative emailed me stating that the "dual layer" firmware for the ddw-081 will be coming out in the very near future, and that she will be getting back with me once an ETA (for the firmware release) is confirmed. :D
gregdep
Postby Vanderlow on Thu Mar 04, 2004 9:02 pm
DVD9 firmware upgrade? is that what your talking about? Do you think she knew what dual layer meant?
Vanderlow
Postby Kool on Thu Mar 04, 2004 10:08 pm
DVD9 firmware upgrade!! That's what I like to see instead of dual format upgrade. I gave up on writing DVD-R. Its a nice to have this additional feature but what's the point when you can burn @8x and get great quality for DVD+R?
Kool
Postby Ian on Thu Mar 04, 2004 11:16 pm
That's interesting news if its true. Hopefully Ciryadin can give us the whole story.
Postby Ian on Thu Mar 04, 2004 11:47 pm
I emailed one of my contacts at Nu-Tech USA and like gregdep said, they are planning on adding this feature.
Postby nicw on Fri Mar 05, 2004 2:00 am
I have checked with NU Korea about this info and is false. Whoever told u this is leading you up the garden path. The burner will be a whole new burner with different hardware and faster speeds.
cheers
NicW
www.dvdinfopro.com
nicw
Postby zebraX on Fri Mar 05, 2004 2:03 am
I can echo that here Nic. Nu have not made any official statement nor have they told me when I Q'ed them about a potential dual layer firmware upgrade.
Uhhhh....its not like - an early april fools joke I hope! As this was mean indeed....DVD9 would have been nice.
zebraX
Postby Ciryadin on Fri Mar 05, 2004 4:38 am
Estimations are Q2-Q3.
-= Looking Into The Abyss, Do You Feel Torture Or Bliss=-
NU-Europe
Field Application Engineer
Ciryadin
Postby gregdep on Fri Mar 05, 2004 1:01 pm
received another email from a different contact and they stated the same thing..... ETA ~Q2/Q3 for a firmware upgrade....
maybe they will have both... a new burner, and a firmware upgrade for other drives....
i guess time will tell :)
gregdep
dual layer
Postby dvdevil on Sat Mar 06, 2004 6:14 am
Ciryadin must know he is from NU-TECH :)
dvdevil
Postby Ian on Mon Mar 08, 2004 3:44 pm
OK, I got another email from Nu Tech. This time it was from one of their engineers. According to him, they might support DVD+R9 in their next
generation drive, but not the DDW-061 or DDW-081. Ciryadin, can you verify this?
Re: dual layer
Postby Ciryadin on Tue Mar 09, 2004 10:56 am
dvdevil wrote:Ciryadin must know he is from NU-TECH :)
Im not NU Tech, Im NUE, as in NU-Europe :)
but estimations are late q2 minimal prolly later
NU-Europe
Ciryadin
Re: dual layer
Postby gregdep on Tue Mar 09, 2004 7:04 pm
estimations for what? the next generation.... or adding dvd+r9 support to current models (61,81)?
gregdep
Postby Ciryadin on Thu Mar 11, 2004 10:13 am
Ian wrote:OK, I got another email from Nu Tech. This time it was from one of their engineers. According to him, they might support DVD+R9 in their next
Dual-Layer will not be supported in DDW-061/081 (might change but no info that this will happen)
NU-Europe
Ciryadin
Postby tuxedomoon on Mon Mar 15, 2004 7:37 pm
tuxedomoon
nu drive and ps2 dvd
Postby kable on Thu Mar 18, 2004 4:59 pm
I have a DDW-081 and when i put in a PS2 dvd it hangs the drive, it ties up the bus and slows the computer. The only way to eject the disk is to reboot the computer.
The drive has the new firmware pre installed at the factory.
I am not very happy because thats the main reason i purchased the burner.
Is this problem unique to this drive in general, or is it the firmware? I emailed NU and the guy said to try to revert to older single format firmware. I dont want to do this unless I know that the PS2 disks will work with the drive.
Has anyone else put in PS2 disks and if so, what was your success / or lack there of?
kable
Postby Kool on Thu Mar 18, 2004 5:16 pm
I have sucessfully copied a few PS2 games on the plus firmware. Haven't tried the dual firmware though.
Kool
dual layer
Postby kable on Sat Mar 20, 2004 10:59 pm
how the hell could the drive support dual layer, wouldnt that require a hardware upgrade. why are people eving hopeing that this drive could do dual layer with a software update?
kable
Postby OC-Freak on Sun Mar 21, 2004 11:36 am
What discs are you using?
Stick to god quality DVD+R, not DVD-R as they are not yet written correctly with this drive.
www.cdfreaks.com reviewer and forum administrator.
OC-Freak
PreviousNext
