Tazan007
Well, I gave in and bought a Liteon so I can do the PI/PO scans on the burned media. I have the NuTech and the Liteon 811S and using Kprobe, the NuTech consistently has lower PI and PO errors no matter which speed read speed I use on the test with the Liteon. The NuTech has far better write quality and they seem to have fixed the spike when it changes speeds at 6x to 8x. Can someone else confirm no spikes with the bx30 pro firmware? Also, has anyone tried the new DUAL format firmware? I hope it works well and hopefully it does not reduce the burn quality of the +R format as it did with the b360 firmware.
Well profesional tests prooved the same. While Nutech 8x burner came with quite decent 4x burning out of the box and quite good support for ricoh 4x @8x media. The Lite On 811S didn't performed that well.
Now newer firmwares have improved both drives and Lite On is closing th gap again. Still why do Lite On dvd burners allways need a firmware of 3 or more to get close to the competition.
Still the Nutech drive is ahead from the Lite On 811s.
well, I couldn't wait until morning. It seems the liteon drives have problems reading CMC media in general and they are horrible at writing to CMC media. The 2.4X CMC DVD+R was burned with the same data as the Nutech, here are the results for the short scan I did,
Liteon burned 2.4x CMC DVD+R
-Avg PI >800
-Avg PO >5
NuTech burned 2.4x CMC DVD+R
-Avg PI >124
-Avg PO >0.1
So either the Liteon drive has bad results when reading CMC disks or both of the drives are horrible at writing on CMC dye. But the Liteon 811S still has far worse write quality. At this point I am glad I got the Nutech. I may get brave enough to test out the new dual format firmware and see if it will burn on my Verbatim 2x DVD-R's. Will report back in a few days.
The problem here is the CMC 2.4x media. Now there 4x media has improved much still the drive has to support it.
And at this time I can say Lite On 811S and CMC don't work together.
(Pioneer a06 and the same media show a ussable result so it's not the media but more the fact that CMC is bad optimised by Lite On.
On one hand this is fair. If time is limited a lot of other media needs still to be optimised I would prefer to spend the time on quality 8x media and not on CMC's 4x media. Still they could have done a bit more support befor releasing it.
About Nutech DVD-R support let's see what's recommended.
Nunuverse site1.Memorex DVD-R
2.MCC DVD-R
3.TAIYO-YUDEN DVD-R
4.CMC DVD-R
What is Memorex DVD-R ? - I thought Memorex just bought media from a lot of factories so may we expect that it works from these factory's as long as it says Memorex or have Nutech screwed up on this one.
The other 3 are just all MKM AZO based media. Not a surprise that they got all 3 listed. Now let's hope that they gave CMC a fair change.
