by hoxlund on Thu Dec 11, 2003 7:38 pm
you guys are doing things way harder than you need to, dvdshrink does rip and if you want or need to, it also encodes it to fit on 1 dvd-+r
the whole not wearing out your dvd-rom is nonsense, either way your using your dvd-rom the same amount
and yes dvdshrink can do a exact copy and put it on your hard drive, thats what the program was made for, and if the dvd doesn't fit when you use dvd decryptor? then you use dvdshrink, so why not cut out the 1st step?
