gm2015 wrote:I just bought Sony 8X DVD-Rs, and when I try to record on them, I get this response:
Illegal disc
NEC DVD_RW ND 1300A
Could not perform start of Disc-at-once
Burn process failed at 2.4x (3,324 KB/s)
I also get this message when trying to burn at other speeds (2x, 1x and "maximum").
Just yesterday, I was able to play a Sony 8x DVD-R disc that was burned in someone else's computer.
Why would my NEC play a Sony DVD-R, but not record on them? Is it that my NEC can play, but not record on Sonys, or did I just end up with a bad batch of discs?
Note: These Sonys usually sell at Staples for $13.98 (or $14.98) for a ten pack, but these are marked down to $8.98 (with an additional $4 taken off at the register, for a total of $4.98 plus tax), which means that Staples was very eager to get rid of them.
dolphinius_rex wrote:Some drives can do 2.4x (or even 2.5x!) on DVD-R/RWs. The BenQ DW1620 and DW1640 are good examples
ItalianJob wrote:I buy a lot of Fuji DVD+R 8X YUDENT000 T02 @ www.cdrvierge.com for my friends and I these late days and there was stamped on the box : made in Japan, packaged in China. This is for the "cost" explanation.
(In Europe, I confirm that these Fuji are excellent : max PIF = 4 on my BenQ 1620Pro B7V9 in most case and scans are fluently good.)
dolphinius_rex wrote:Only Taiyo Yuden's lowest grade and value line discs are normally packaged in China. Usually those discs must be sold as 4x DVDRs, as that is all that Taiyo Yuden certifies them for
Scour wrote:dolphinius_rex wrote:Only Taiyo Yuden's lowest grade and value line discs are normally packaged in China. Usually those discs must be sold as 4x DVDRs, as that is all that Taiyo Yuden certifies them for
But T02 are 8x-certified, I think?
gm2015 wrote:Dolphinus: You'll be interested to know that tonight, I burned a Fuji TY CDR and had some real problems with it. It was an audio CD that didn't play properly on the last track. I used CD Speed to check it and here's what I got:
C2 errors:
Maximum: 4113
Average: 54.37
Total: 250370
All of the errors occurred in the last few minutes of the disc. I've never got numbers this bad before, and the transfer test was just as bad.
"I doubt your 1300A (4X+/-R?) can handle those 8X -R discs. Anyway, is 2.4X a speed for -R discs? AFAIK, only 2X, 4X and 1X exist?"
Bhairav:
I'm fairly new to DVD burning, so maybe I'm misundertanding you. Are you suggesting that once the 8x discs become prevalent, and the 4x discs start disppearing from stores, I might have a hard time finding DVDRs that I can use with my NEC 1300A (which is only a little more than a year old)?
C2 errors:
Maximum: 4113
Average: 54.37
Total: 250370
Actually, I don't think Taiyo Yuden has their T02 code certified, no need to. But all TAIYO YUDEN certifies their Value Pak media for is 4x.
RJW wrote:dolphinius_rex wrote:
But T02 are 8x-certified, I think?Actually, I don't think Taiyo Yuden has their T02 code certified, no need to. But all TAIYO YUDEN certifies their Value Pak media for is 4x.
Certified by who ? By TY themselves YES.
The media is not approved by Philips if your talking about that.
About packageing.
More as the value line is packaged in china. However I agree that for non branded media CHINA is the place for VALUE LINE.
About FUJI.The problem is the variance. You can have a excellent pack and next a quite crap pack. Really in the past TY was guaranteed quality however with the huge fluctuations in FUJI (and in some other media) and with the fact of licensing there code to disc's which perform even worse as FUJI. (Okay that's still not completely official.)
I think I can not longer recommend TY.
Looks like it's back to the old days and I will just recommend brands. Because manufacturer codes seem to say even less about quality and support.
Halc wrote:However, I'm starting to see variance (or at least a bit too many unsuccessful burns) with Mitsubishi (MCC 03RG20) DVD-R 16x discs (made in taiwan) that are available in EU. Nothing alarming, but just that 8x (and of course 16x) burns can fail on modern burners that have official support for these discs. When burns work, they scan quite well in six different drives (diff puh, diff chipset, diff transport).
regards,
halc
Gary Kokkin wrote:About TY packaging in China,I think are rumours or fake TY.
http://club.cdfreaks.com/showthread.php ... utsourcing
Gary Kokkin wrote:About TY quality :
Never bought bad batch Fuji TY media from various (and serious) sources in Europe.-In all media brands, happened variance of media quality .Always huge production of each media ,cause the possibility of fluctuations .This is normal !
-The manafucturer's problem is to control this,less or max. depends on it's reputation-In other side ,each factory pressed by each order of OEM production, for cost and time of availibilty-In advance of these, each factory ,must sell all bad control media (usually as B' Grade) -So there is not any exception for a brand like Fuji .-So if you want quality media ,take care of trade combination of Manafacturer/Brand/retailer.
Fuji,Sony,Plextor,Verbatim still best TY choice
http://www.videohelp.com/dvdmedia.php?d ... N000T02%20
Ian wrote:I haven't seen the "Packaged in China" label yet. Anyone have a picture?
They are not rumours, and it is not fake. It is 100% fact. How do I know? Because my boxes of Japanese Taiyo Yuden 4x DVD-Rs come with "Packaged in China" stamped on them. And it only happens with Value Line products from Taiyo Yuden. And no, my Taiyo Yuden's are not fake.
Can you post how identified your unbranded TY media if their genuine ? (except a simple label mentioned MIJ)
They are Value Line 4x DVD-Rs, with TYG02 code. They have the proper GGxxxxxxx style serial number.
| All Content is Copyright (c) 2001-2026 CDRLabs Inc. |
